はじめに
If the device is failing to charge it may be necessary to replace the charging port. The most difficult step will be soldering the charging port, it is important to make sure you have all tools required and follow the instructions precisely.
必要な工具と部品
Push out the battery connector using the spudger.
Swing the battery connector clear of the connector socket.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
