メインコンテンツにスキップ
HP 15-dy2024nr Battery Replacement
必要な工具と部品
  1. HP 15-dy2024nr Battery Replacement, Back Cover: 手順 1、 2の画像 1 HP 15-dy2024nr Battery Replacement, Back Cover: 手順 1、 2の画像 2
    • Use a spudger to peel one corner of each of the rubber feet from the bottom of the laptop.
    • Gently peel the feet from the laptop using the spudger revealing the screws underneath.
    • If the rubber foot peels away but leaves adhesive behind you must peel the adhesive away before removing the screws.
  2. HP 15-dy2024nr Battery Replacement: 手順 2、 3の画像 1 HP 15-dy2024nr Battery Replacement: 手順 2、 3の画像 2 HP 15-dy2024nr Battery Replacement: 手順 2、 3の画像 3
    • Use a Phillips #1 screwdriver to remove:
    • Two 2.5mm x 6mm screws
    • Six 2mm x 6mm screws
    • Be sure to keep different screw sizes separated.
  3. HP 15-dy2024nr Battery Replacement: 手順 3、 3の画像 1 HP 15-dy2024nr Battery Replacement: 手順 3、 3の画像 2 HP 15-dy2024nr Battery Replacement: 手順 3、 3の画像 3
    • Insert an iFixit opening tool into the seam between the keyboard area and bottom cover.
    • Using another iFixit opening tool, slide along the seam to unhook the clips.
    • There are clips all the way around the seam. You may hear a popping sound as the clips come loose. This step may require some force to separate the back cover from the laptop.
    • When the front of the laptop is open, you can use your finger to hold a corner open then slide an iFixit opening tool along the seam toward the back corner.
    • After the clips have been released, flip the laptop over and lift the cover.
  4. HP 15-dy2024nr Battery Replacement, Battery: 手順 4、 3の画像 1 HP 15-dy2024nr Battery Replacement, Battery: 手順 4、 3の画像 2 HP 15-dy2024nr Battery Replacement, Battery: 手順 4、 3の画像 3
    • Remove five 2.0mm x 3.0mm screws using a Phillips #00 screwdriver.
    • Use the iFixit opening picks to lift the battery away from the laptop.
  5. HP 15-dy2024nr Battery Replacement: 手順 5、 3の画像 1 HP 15-dy2024nr Battery Replacement: 手順 5、 3の画像 2 HP 15-dy2024nr Battery Replacement: 手順 5、 3の画像 3
    • Be aware that the battery is plugged into the motherboard.
    • Unplug the battery from the motherboard.
    • Lift the battery away from the laptop and remove.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Konnor Young
メンバー登録日: 09/27/22
523 ポイント
4のガイドは作成済み
チーム
Utah Tech University, Team 1-4, McMurrin Fall 2022 Utah Tech University, Team 1-4, McMurrin Fall 2022人のメンバー
UTAHTECH-MCMURRIN-F22S1G4
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 45
今までの合計 789
