メインコンテンツにスキップ
HP 15-ay114cy Speakers Replacement
必要な工具と部品
  1. HP 15-ay114cy Speakers Replacement, Orient the Laptop: 手順 1、 1の画像 1
    • Orient the Laptop so the HP logo is facing the table and the battery tabs are accessible.
    • Ensure the laptop is powered off before moving forward.
  2. HP 15-ay114cy Speakers Replacement, Push out the Battery: 手順 2、 2の画像 1 HP 15-ay114cy Speakers Replacement, Push out the Battery: 手順 2、 2の画像 2
    • Place your index fingers on each of the two battery holder clips.
    • Using your index fingers, push the battery holder clips inwards (towards the center of the laptop).
  3. HP 15-ay114cy Speakers Replacement, Remove the Battery: 手順 3、 2の画像 1 HP 15-ay114cy Speakers Replacement, Remove the Battery: 手順 3、 2の画像 2
    • After the battery clips are pushed in, use either hand to grab hold of the battery.
    • Gently push up to remove the battery.
  4. HP 15-ay114cy Speakers Replacement, Unscrew the Back Cover: 手順 4、 2の画像 1 HP 15-ay114cy Speakers Replacement, Unscrew the Back Cover: 手順 4、 2の画像 2
    • Use a Phillips #0 screwdriver to remove the 8 mm Phillips-head screws that are holding on the bottom cover of the Laptop.
  5. HP 15-ay114cy Speakers Replacement, Remove the Disk Drive: 手順 5、 2の画像 1 HP 15-ay114cy Speakers Replacement, Remove the Disk Drive: 手順 5、 2の画像 2
    • Grab a hold of the disk drive and carefully pull it away from the computer.
    • Continue to slide the disk drive out of the laptop until fully removed.
    • Due to the removal of the battery, no power is available to open the disk drive through the use of the eject button.
    • Make sure to pull out the disk drive at a 90 degree angle as demonstrated. Do not attempt to wiggle the drive out of the laptop.
    • There will be resistance when removing the drive. Mishandling may cause broken wires, which could make your disk drive inoperative.
  6. HP 15-ay114cy Speakers Replacement, Remove the Back Cover: 手順 6、 3の画像 1 HP 15-ay114cy Speakers Replacement, Remove the Back Cover: 手順 6、 3の画像 2 HP 15-ay114cy Speakers Replacement, Remove the Back Cover: 手順 6、 3の画像 3
    • Place a plastic opening tool in-between the upper and lower pieces of the bottom cover.
    • Using your hands and the plastic opening tool, gently separate the cover from the frame.
    • Slowly remove the bottom cover from the base of the laptop.
    • Using metal pry tools can damage your device.
  7. HP 15-ay114cy Speakers Replacement, Remove the Speakers: 手順 7、 3の画像 1 HP 15-ay114cy Speakers Replacement, Remove the Speakers: 手順 7、 3の画像 2 HP 15-ay114cy Speakers Replacement, Remove the Speakers: 手順 7、 3の画像 3
    • Using your index finger and thumb, lift the right speaker to remove it from its housing. This will give enough room to pull the wiring harness from the adapter.
    • Follow the connected wire to the harness.
  8. HP 15-ay114cy Speakers Replacement, Insert the Replacement Speakers: 手順 8、 3の画像 1 HP 15-ay114cy Speakers Replacement, Insert the Replacement Speakers: 手順 8、 3の画像 2 HP 15-ay114cy Speakers Replacement, Insert the Replacement Speakers: 手順 8、 3の画像 3
    • Grabbing the base of the wiring harness, use a bit of force to separate the harness from the motherboard adapter.
    • Lift up the old speakers and remove the wiring from the plastic routing tabs.
終わりに
作成者
4人の作成者と共同で作成されました。
Bradley Evans
メンバー登録日: 01/24/20
613 ポイント
5のガイドは作成済み
チーム
S20S3G#1 S20S3G#1人のメンバー
Local Repair Groups
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 149
