はじめに
Use this guide to replace the touchpad for your HP 14-dq0051dx laptop. This may be helpful if the touchpad is broken or not working.
Before beginning this repair, turn off the laptop and disconnect from the AC adapter.
必要な工具と部品
Turn the laptop upside down so the backside is facing up.
Use a Phillips #1 screwdriver to remove eight screws from the back case.
Use a Phillips #1 screwdriver to remove the four 2.5 mm screws that secure the battery.
Remove the battery from the laptop.
Use the tip of a spudger or your fingernail to flip up the small locking flap from ZIF connector that attaches the touchpad cable to the motherboard.
Pull the ribbon cable out from the connector.
