メインコンテンツにスキップ
HP 10 2101 Battery Replacement
必要な工具と部品
  1. HP 10 2101 Battery Replacement, Back Panel: 手順 1、 1の画像 1
    • Identify the SD card port.
  2. HP 10 2101 Battery Replacement: 手順 2、 1の画像 1
    • Insert the smallest plastic opening tool into the SD card port. Gently pry until the back panel separates from the screen panel.
    • Do not insert opening tool too far. Avoid making contact with the metal inside the port.
  3. HP 10 2101 Battery Replacement: 手順 3、 1の画像 1
    • Slide the opening tool along the seam between the back panel and the screen panel, prying the panels apart as you move around the edges.
  4. HP 10 2101 Battery Replacement: 手順 4、 1の画像 1
    • Separate the back panel from the rest of the device.
  5. HP 10 2101 Battery Replacement, Battery: 手順 5、 1の画像 1
    • Desolder the battery connectors from the motherboard.
  6. HP 10 2101 Battery Replacement: 手順 6、 1の画像 1
    • Pull the bright blue-green tabs to remove the battery from the rest of the device.
    • Pulling the tabs may not fully disconnect the battery from the metal display casing.
  7. HP 10 2101 Battery Replacement: 手順 7、 2の画像 1 HP 10 2101 Battery Replacement: 手順 7、 2の画像 2
    • If the previous step is unsuccessful, wedge the smallest plastic opening tool between the adhesive and the metal display casing.
    • Wedging may apply unsafe pressure on the battery. Be careful not to puncture the battery.
終わりに
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Bryce Harmsen
メンバー登録日: 09/25/18
692 ポイント
5のガイドは作成済み
チーム
Central Washington University, Team S1-G4, Pengilly Fall 2018 Central Washington University, Team S1-G4, Pengilly Fall 2018人のメンバー
CWU-PENGILLY-F18S1G4
4 メンバー
10のガイドは作成済み
2 件のコメント
Do you know where to buy a replacement battery for this device?
Nathan Wells - 返信
Hi Nathan,
Unfortunately HP has not released this battery for sale to the public, as seen at https://parts.hp.com/hpparts/Search_Resu.... It may be worthwhile to contact HP. Here is an email address for their customer service: ''HPparts.sales.ams@hp.com.
Bryce Harmsen - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 1,286
