メインコンテンツにスキップ
HAMILTON C-1 Bacterial Filter Replacement (Dual Limb Circuit Setup)
医療機器
この修理ガイドは医療機器メーカーからの是認を得ておらず、iFixitと医療機器メーカーは提携していません。
  1. HAMILTON C-1 Bacterial Filter Replacement (Dual Limb Circuit Setup), Bacterial Filter: 手順 1、 1の画像 1
    • Orient Hamilton-C1 so the right side of the device is facing you.
  2. HAMILTON C-1 Bacterial Filter Replacement (Dual Limb Circuit Setup): 手順 2、 1の画像 1
    • Disconnect used/contaminated INSPIRATORY bacterial filter from circuit setup
    • Gently twist and pull the used/contaminated bacterial filter from the inspiratory outlet.
    • Next, twist and pull the used/contaminated bacterial filter from the inspiratory limb.
    • The used/contaminated bacterial filter should now be removed from the inspiratory port.
    • In reassembly, a new/non-contaminated INSPIRATORY bacterial filter will be used for this step. In addition, use a twist and pushing motion instead.
  3. HAMILTON C-1 Bacterial Filter Replacement (Dual Limb Circuit Setup): 手順 3、 1の画像 1
    • Disconnect used/contaminated EXPIRATORY bacterial filter from circuit setup
    • Gently twist and pull the used/contaminated bacterial filter from the expiratory outlet.
    • Next, twist and pull the used/contaminated bacterial filter from the expiratory limb.
    • The used/contaminated bacterial filter should now be removed from the expiratory port.
    • In reassembly, a new/non-contaminated EXPIRATORY bacterial filter will be used for this step. In addition, use a twist and pushing motion instead.
  4. HAMILTON C-1 Bacterial Filter Replacement (Dual Limb Circuit Setup): 手順 4、 1の画像 1
    • Your two new bacterial filters should now be installed in their respective inspiratory and expiratory ports.
    • After completing all steps, the end result should look like this:
終わりに
作成者
1人の作成者と共同作成されました。
Luisa Chiu
メンバー登録日: 04/06/20
205 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S7-G11, Paton Spring 2020 Cal Poly, Team S7-G11, Paton Spring 2020人のメンバー
CPSU-PATON-S20S7G11
2 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 15
今までの合計 388
