メインコンテンツにスキップ
Google Pixel 5 Screen Adhesive Installation
必要な工具と部品
  1. Google Pixel 5 Screen Adhesive Installation, Remove adhesive residue from the frame: 手順 1、 3の画像 1 Google Pixel 5 Screen Adhesive Installation, Remove adhesive residue from the frame: 手順 1、 3の画像 2 Google Pixel 5 Screen Adhesive Installation, Remove adhesive residue from the frame: 手順 1、 3の画像 3
    この手順で使用する道具:
    購入する
    • Peel off as much adhesive as you can with a pair of tweezers.
    • Use a spudger to scrape away any lingering adhesive.
    • Don't use metal tools to scrape away adhesive as this will damage the frame.
    • For best results, clean the area underneath the removed adhesive with 90% or greater isopropyl alcohol to prep the surface for the new adhesive.
  2. Google Pixel 5 Screen Adhesive Installation, Remove adhesive residue from the screen: 手順 2、 3の画像 1 Google Pixel 5 Screen Adhesive Installation, Remove adhesive residue from the screen: 手順 2、 3の画像 2 Google Pixel 5 Screen Adhesive Installation, Remove adhesive residue from the screen: 手順 2、 3の画像 3
    • Repeat the previous step for the screen adhesive.
    • Don't use metal tools to scrape away adhesive as this will damage the screen.
    • Don't use isopropyl alcohol near the front camera bracket as it will loosen its adhesive.
  3. Google Pixel 5 Screen Adhesive Installation, Align the adhesive: 手順 3、 2の画像 1 Google Pixel 5 Screen Adhesive Installation, Align the adhesive: 手順 3、 2の画像 2
    • Use the holes in the top right and bottom left corners of the frame to correctly align the adhesive:
    • The top right hole is circular
    • The bottom left hole is oblong
  4. Google Pixel 5 Screen Adhesive Installation, Prepare the adhesive: 手順 4、 1の画像 1
    • Peel away the clear plastic lining to expose the frame side of the adhesive.
  5. Google Pixel 5 Screen Adhesive Installation, Apply the adhesive: 手順 5、 2の画像 1 Google Pixel 5 Screen Adhesive Installation, Apply the adhesive: 手順 5、 2の画像 2
    • Be very careful during this step! The adhesive is very sticky and can't be repositioned once it sticks. Misaligned adhesive can lead to an improper seal.
    • Lower the adhesive onto the frame.
    • Use the holes in the top right and bottom left corners to properly align the adhesive during installation.
  6. Google Pixel 5 Screen Adhesive Installation, Secure the adhesive to the frame: 手順 6、 2の画像 1 Google Pixel 5 Screen Adhesive Installation, Secure the adhesive to the frame: 手順 6、 2の画像 2
    • Use the flat end of a spudger or your fingernail to press down on the adhesive.
    • Slide along the perimeter to secure the adhesive to the frame.
  7. Google Pixel 5 Screen Adhesive Installation, Peel away the outer plastic lining: 手順 7、 2の画像 1 Google Pixel 5 Screen Adhesive Installation, Peel away the outer plastic lining: 手順 7、 2の画像 2
    • Use your fingers to grasp the blue plastic lining near the center and peel it away from the phone.
    • This should leave a thin perimeter of adhesive still covered by blue plastic lining.
  8. Google Pixel 5 Screen Adhesive Installation, Connect the screen: 手順 8、 2の画像 1 Google Pixel 5 Screen Adhesive Installation, Connect the screen: 手順 8、 2の画像 2
  9. Google Pixel 5 Screen Adhesive Installation, Peel away the remaining plastic lining: 手順 9、 2の画像 1 Google Pixel 5 Screen Adhesive Installation, Peel away the remaining plastic lining: 手順 9、 2の画像 2
    • Peel away the blue plastic lining to expose the perimeter adhesive.
  10. Google Pixel 5 Screen Adhesive Installation, Position the screen: 手順 10、 3の画像 1 Google Pixel 5 Screen Adhesive Installation, Position the screen: 手順 10、 3の画像 2 Google Pixel 5 Screen Adhesive Installation, Position the screen: 手順 10、 3の画像 3
    • Position the screen so it lays on the frame.
  11. Google Pixel 5 Screen Adhesive Installation, Press down the screen corners: 手順 11、 2の画像 1 Google Pixel 5 Screen Adhesive Installation, Press down the screen corners: 手順 11、 2の画像 2
    • Press down the corners of the screen to secure them to the frame.
  12. Google Pixel 5 Screen Adhesive Installation, Secure the screen to the frame: 手順 12、 3の画像 1 Google Pixel 5 Screen Adhesive Installation, Secure the screen to the frame: 手順 12、 3の画像 2 Google Pixel 5 Screen Adhesive Installation, Secure the screen to the frame: 手順 12、 3の画像 3
    • Press down on the edges of the screen.
    • Slide along the perimeter to secure it to the frame.
    • You can heat the perimeter of the screen to soften the adhesive and help it bond more securely.
終わりに
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Pixel 5 Answers community for help.
20 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Chayton Ritter
メンバー登録日: 08/21/20
19,823 ポイント
105のガイドは作成済み
チーム
Guide Team Guide Team人のメンバー
Staff
8 メンバー
8,357のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 52
過去 30 日: 316
今までの合計 7,523
