メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Google Pixel 3 Back Cover Adhesive Installation
必要な工具と部品
  1. Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the frame: 手順 1、 3の画像 1 Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the frame: 手順 1、 3の画像 2 Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the frame: 手順 1、 3の画像 3
    • Pick and scrape away the old adhesive from the frame.
    • Use a spudger to scrape away any lingering adhesive.
    • Don't use metal tools to scrape away adhesive as this will damage the frame.
    • For best results, clean the area underneath the removed adhesive with 90% or greater isopropyl alcohol to prep the surface for the new adhesive.
    FixBotに聞いてみる
  2. Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the back cover: 手順 2、 3の画像 1 Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the back cover: 手順 2、 3の画像 2 Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the back cover: 手順 2、 3の画像 3
    • Repeat the previous step for the back cover adhesive.
    • Don't use metal tools to scrape away adhesive as this will damage the back cover coating.
    • Don't use isopropyl alcohol near the rear camera bracket as it will damage its adhesive and foam.
    FixBotに聞いてみる
  3. Google Pixel 3 Back Cover Adhesive Installation, Prepare the replacement adhesive: 手順 3、 1の画像 1
    • Peel away the clear plastic lining to expose the frame side of the replacement adhesive.
    FixBotに聞いてみる
  4. Google Pixel 3 Back Cover Adhesive Installation, Apply the adhesive: 手順 4、 2の画像 1 Google Pixel 3 Back Cover Adhesive Installation, Apply the adhesive: 手順 4、 2の画像 2
    • Be very careful during this step! The adhesive is very sticky and can't be repositioned once it sticks. Misaligned adhesive can lead to an improper seal.
    • Lower the adhesive onto the frame.
    • Use the rear camera and corners to properly align the adhesive.
    FixBotに聞いてみる
  5. Google Pixel 3 Back Cover Adhesive Installation, Secure the adhesive to the frame: 手順 5、 2の画像 1 Google Pixel 3 Back Cover Adhesive Installation, Secure the adhesive to the frame: 手順 5、 2の画像 2
    • Use the flat end of a spudger or your fingernail to press down on the adhesive.
    • Slide along the perimeter to secure the adhesive to the frame.
    FixBotに聞いてみる
  6. Google Pixel 3 Back Cover Adhesive Installation, Peel away the outer plastic lining: 手順 6、 2の画像 1 Google Pixel 3 Back Cover Adhesive Installation, Peel away the outer plastic lining: 手順 6、 2の画像 2
    • Peel away the blue outer plastic lining on the back cover side of the adhesive.
    FixBotに聞いてみる
  7. Google Pixel 3 Back Cover Adhesive Installation, Connect the fingerprint sensor cable: 手順 7、 2の画像 1 Google Pixel 3 Back Cover Adhesive Installation, Connect the fingerprint sensor cable: 手順 7、 2の画像 2
    この手順で使用する道具:
    • Use tweezers or your fingers to position the fingerprint sensor cable over its connector on the motherboard.
    • Use the flat end of a spudger or your finger to press down on the connector to secure it to the motherboard.
    FixBotに聞いてみる
  8. Google Pixel 3 Back Cover Adhesive Installation: 手順 8、 3の画像 1 Google Pixel 3 Back Cover Adhesive Installation: 手順 8、 3の画像 2 Google Pixel 3 Back Cover Adhesive Installation: 手順 8、 3の画像 3
    • Use tweezers or your fingers to place the bracket over the fingerprint sensor cable.
    FixBotに聞いてみる
  9. Google Pixel 3 Back Cover Adhesive Installation: 手順 9、 2の画像 1 Google Pixel 3 Back Cover Adhesive Installation: 手順 9、 2の画像 2
    • Use a Phillips PH00 screwdriver to install the two 4.1 mm screws securing the bracket to the frame.
    FixBotに聞いてみる
  10. Google Pixel 3 Back Cover Adhesive Installation, Peel away the remaining plastic lining: 手順 10、 2の画像 1 Google Pixel 3 Back Cover Adhesive Installation, Peel away the remaining plastic lining: 手順 10、 2の画像 2
    • Peel away the red plastic lining to expose the back cover side of the adhesive.
    FixBotに聞いてみる
  11. Google Pixel 3 Back Cover Adhesive Installation, Secure the back cover to the frame: 手順 11、 2の画像 1 Google Pixel 3 Back Cover Adhesive Installation, Secure the back cover to the frame: 手順 11、 2の画像 2
    • Lower the back cover onto the frame.
    • Press down on all edges of the back cover to secure it to the frame.
    • To help the adhesive bond more securely, heat the perimeter of the back cover and then place the phone face-down under a heavy stack of books for 30 minutes.
    FixBotに聞いてみる
終わりに
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Pixel 3 Answers community for help.
11 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Chayton Ritter
メンバー登録日: 08/21/20
26,685 ポイント
105のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 17
過去 30 日: 97
今までの合計 4,449
