Remove the faceplate by carefully prying around the edge.
Loosen the clips on the edge, then pull the faceplate off. Be aware that there is double stick tape holding it in place(indicated by the red arrow).
Remove the four PH000 Phillips screws outlined in red.
Gently remove the board. As you lift the board, the computer chip (outlined in orange) will separate from the motherboard.
14 の人々がこのガイドを完成させました。
5 件のコメント
Just finished replacing the lens in the GoPro 4 Black here at work (that I dropped and broke). Other than a missing step and struggling with reconnecting the last ribbon cable during reassembly, it when well. After seeing these instructions, I was confident I could replace the lens. Thanks for posting this. It was very helpful.
James Bell - 返信
How do people manage to get the last ribbon cable in place?
It's tricky. Reconnecting that small ribbon cable took me the longest of all of the steps to complete. I used the curved needle tweezers in the kit. It can be done, so keep trying.
sam -
I'm looking at the flags and it is saying that this is a archived version and I should use the update version. But I don't know how to find that.
Sorry about that! It looks like a new set of guides is in the works, but nothing has been published as yet. So for the moment, the flag is misleading, and this is the only available version of the guide.
