この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Proper maintenance of the Giant Reign 2 bicycle includes installation and lubrication of a new headset. This guide will clearly show you how to perform this maintenance quickly and safely, extending the life of your bike.
必要な工具と部品
Using the 4mm Allen wrench, partially unscrew the 4 (22mm) hex screws on the front of the axle casing to allow the axle to slide freely.
Using the 8mm Allen wrench, loosen the axle screw until 1/2 of the axle screw is visible.
Push the axle screw to reveal the axle rod on the other side.
Using the 8mm Allen wrench, unscrew 2 (32mm) screws to release the brake calipers from the fork.
ある他の人がこのガイドを完成しました。
