メインコンテンツにスキップ
Garmin Nuvi 42LM Motherboard Replacement
必要な工具と部品
  1. Garmin Nuvi 42LM Motherboard Replacement, Back Cover: 手順 1、 3の画像 1 Garmin Nuvi 42LM Motherboard Replacement, Back Cover: 手順 1、 3の画像 2 Garmin Nuvi 42LM Motherboard Replacement, Back Cover: 手順 1、 3の画像 3
    • Remove the four screws on the back of the GPS using the T5 Torx screwdriver.
  2. Garmin Nuvi 42LM Motherboard Replacement: 手順 2、 3の画像 1 Garmin Nuvi 42LM Motherboard Replacement: 手順 2、 3の画像 2 Garmin Nuvi 42LM Motherboard Replacement: 手順 2、 3の画像 3
    • Pry the GPS open using a plastic opening tool.
    • When prying open the device, use caution to avoid damaging the motherboard.
  3. Garmin Nuvi 42LM Motherboard Replacement, Motherboard: 手順 3、 3の画像 1 Garmin Nuvi 42LM Motherboard Replacement, Motherboard: 手順 3、 3の画像 2 Garmin Nuvi 42LM Motherboard Replacement, Motherboard: 手順 3、 3の画像 3
    • Using the T5 Torx screwdriver, remove the two screws located on the motherboard.
    • There are two screws - one in the back and one in the front.
  4. Garmin Nuvi 42LM Motherboard Replacement: 手順 4、 1の画像 1
    • Move the motherboard from from its designated location on the GPS.
    • Do not pull on red, green, and black cables when repositioning the motherboard.
  5. Garmin Nuvi 42LM Motherboard Replacement: 手順 5、 2の画像 1 Garmin Nuvi 42LM Motherboard Replacement: 手順 5、 2の画像 2
    • Gently unplug the red, green, and black bundled cable to remove the battery.
  6. Garmin Nuvi 42LM Motherboard Replacement: 手順 6、 2の画像 1 Garmin Nuvi 42LM Motherboard Replacement: 手順 6、 2の画像 2
    • Use blue plastic opening tool to carefully pry the battery from the GPS.
    • You might need to use additional force when prying because there is adhesive glue on the back of the battery.
  7. Garmin Nuvi 42LM Motherboard Replacement: 手順 7、 1の画像 1
    • Using a soldering iron, desolder the black and blue wires connected to the motherboard.
    • Once the black and blue wires are desoldered, llift the motherboard out and away from the device.
    • Check out this awesome guide on how to solder and desolder connections.
終わりに
作成者
2人の作成者と共同で作成されました。
Elina Zhukov
メンバー登録日: 01/18/17
558 ポイント
5のガイドは作成済み
チーム
Eastern Washington University, Team 2-1, Crane Winter 2017 Eastern Washington University, Team 2-1, Crane Winter 2017人のメンバー
EWU-CRANE-W17S2G1
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 397
