メインコンテンツにスキップ
Garmin Nuvi 2589LMT Speaker Replacement
必要な工具と部品
  1. Garmin Nuvi 2589LMT Speaker Replacement, Back Panel Assembly: 手順 1、 1の画像 1
    • Using the T5 Torx Screwdriver, remove all 4 of the 5.7mm screws from the back of the device.
  2. Garmin Nuvi 2589LMT Speaker Replacement: 手順 2、 2の画像 1 Garmin Nuvi 2589LMT Speaker Replacement: 手順 2、 2の画像 2
    • Using the plastic opening tools, pry the shorter sides of the device apart.
    • Once a gap has formed at the top of the device, insert the opening tool into the gap and slide it along the top of the device. Repeat for the bottom edge of the device to separate the LCD screen from the back.
    • Do not disconnect or tear the ribbon wiring, located at the bottom of the motherboard, when removing the back of the device.
  3. Garmin Nuvi 2589LMT Speaker Replacement, Speaker: 手順 3、 1の画像 1
    • Wedge the speaker from the device, using the small plastic opening tool.
    • The speaker is held in place by adhesive tape on the outer rim. Because the speaker is still connected to the motherboard, pry the speaker away from the device gently.
  4. Garmin Nuvi 2589LMT Speaker Replacement: 手順 4、 1の画像 1
    この手順で使用する道具:
    購入する
    • Using tweezers, remove the tape covering the speaker connection to the motherboard.
  5. Garmin Nuvi 2589LMT Speaker Replacement: 手順 5、 1の画像 1
    • Using a soldering iron, desolder the wire connection at the soldering points between the speaker and the motherboard to remove.
    • Learn more about soldering and desoldering connections here.
終わりに
作成者
3人の作成者と共同で作成されました。
Adam Ferraro
メンバー登録日: 10/04/16
920 ポイント
8のガイドは作成済み
チーム
USF Tampa, Team 1-2, Nance Fall 2016 USF Tampa, Team 1-2, Nance Fall 2016人のメンバー
USFT-NANCE-F16S1G2
4 メンバー
8のガイドは作成済み
コメント 1 件
What size was the speaker in inches or mm? How many ohms was it? Where did you find the replacement?
george.terbush - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 13
今までの合計 359
