はじめに
If your GPS device is not responding to voice activation, use this guide to replace a defective microphone on your Garmin NUVI 2589LMT device. This guide will show you how to safely remove the microphone by soldering.
必要な工具と部品
Using the T5 Torx Screwdriver, remove all 4 of the 5.7mm screws from the back of the device.
Using a soldering iron, desolder the wire connection at the two soldering points between the microphone and the motherboard to remove.
もう少しです!
終わりに
