メインコンテンツにスキップ
Garmin Nuvi 2455LMT Mother Board Replacement
必要な工具と部品
  1. Garmin Nuvi 2455LMT Mother Board Replacement, Back Panel Assembly: 手順 1、 1の画像 1
    • Remove the four 2.5mm screws from the back assembly with a Torx #04 Screwdriver.
    • Holding the GPS with a free hand while unscrewing the small screws will help stabilize the device.
  2. Garmin Nuvi 2455LMT Mother Board Replacement: 手順 2、 2の画像 1 Garmin Nuvi 2455LMT Mother Board Replacement: 手順 2、 2の画像 2
    • Use the plastic opening tool on all four sides of the device to open the Garmin Nuvi LMT2455 Back Panel.
    • To properly remove the back cover assembly pry open both the back and sides of the assembly.
  3. Garmin Nuvi 2455LMT Mother Board Replacement: 手順 3、 3の画像 1 Garmin Nuvi 2455LMT Mother Board Replacement: 手順 3、 3の画像 2 Garmin Nuvi 2455LMT Mother Board Replacement: 手順 3、 3の画像 3
    • Open the device carefully being wary of the orange band that is going from the screen to the motherboard.
    • Remove the orange band by carefully lifting the lip that connects it to the motherboard.
  4. Garmin Nuvi 2455LMT Mother Board Replacement, Mother Board: 手順 4、 1の画像 1
    • Remove the two 1.0mm 04# Torx screws from the mother board assembly
    • One screw can be found directly to the right of the battery and one screw can be found behind the orange band.
    • Hold the GPS with a free hand to ensure stability.
  5. Garmin Nuvi 2455LMT Mother Board Replacement: 手順 5、 2の画像 1 Garmin Nuvi 2455LMT Mother Board Replacement: 手順 5、 2の画像 2
    この手順で使用する道具:
    購入する
    • Place the screen portion of the GPS face down.
    • Remove the mother board from the plastic back panel.
    • Disconnect the battery with tweezers by gripping the white socket displayed in the photo. Wiggle the white socket out of the mother board.
  6. Garmin Nuvi 2455LMT Mother Board Replacement: 手順 6、 1の画像 1
    • Use a soldering tool to de-solder the connection to the motherboard. Refer to the iFixit Soldering guide to see how
終わりに
作成者
6人の作成者と共同で作成されました。
Nathaniel Williams
メンバー登録日: 09/19/16
264 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 2-3, Blackwell Fall 2016 USF Tampa, Team 2-3, Blackwell Fall 2016人のメンバー
USFT-BLACKWELL-F16S2G3
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 11
今までの合計 542
