メインコンテンツにスキップ
Game Boy Screen Replacement
必要な工具と部品
  1. Game Boy Screen Replacement, Batteries: 手順 1、 2の画像 1 Game Boy Screen Replacement, Batteries: 手順 1、 2の画像 2
    • Switch your Game Boy off and remove the cartridge.
  2. Game Boy Screen Replacement: 手順 2、 3の画像 1 Game Boy Screen Replacement: 手順 2、 3の画像 2 Game Boy Screen Replacement: 手順 2、 3の画像 3
    • Use a fingernail (or small coin) to push down on the battery door latch and remove the battery door.
    • The release latch is a plastic spring clip. If your Game Boy is getting on in years, be careful as the plastic may be brittle.
    • When you're replacing the cover, be sure to get its two plastic tabs into the slots in the bottom of the battery compartment before pushing the cover back in place.
  3. Game Boy Screen Replacement: 手順 3、 2の画像 1 Game Boy Screen Replacement: 手順 3、 2の画像 2
    • Use a fingernail to pry each battery outward from the positive (+) terminal to remove them.
    • Dispose of used batteries properly!
    • Remove the batteries from your Game Boy before storing it for more than a month or so.
  4. Game Boy Screen Replacement, Outer Case: 手順 4、 1の画像 1
    • Remove the six Triwing screws from the back of the device.
  5. Game Boy Screen Replacement: 手順 5、 1の画像 1
    • Gently separate the device's front casing from the back casing after you remove the screws.
    • Be careful not to completely separate the casing halves, as they are still joined by a large ribbon cable that may be damaged.
  6. Game Boy Screen Replacement: 手順 6、 1の画像 1
    • Slide the front side of the casing down to expose the ribbon cable connector.
  7. Game Boy Screen Replacement: 手順 7、 1の画像 1
    • Grip the ribbon connector with your thumb and forefinger. Pull down gently until the connector, not the ribbon itself, comes out of its socket.
    • Separate the front and back casings.
  8. Game Boy Screen Replacement, Screen: 手順 8、 1の画像 1
    • Remove the ten screws that connect the circuit board to the outer case.
  9. Game Boy Screen Replacement: 手順 9、 2の画像 1 Game Boy Screen Replacement: 手順 9、 2の画像 2
    • Remove the circuit board from the outer case using a plastic opening tool.
    • Take care to gently pry around the entire outside edge of the circuit board until you can easily remove the board without force.
  10. Game Boy Screen Replacement: 手順 10、 1の画像 1
    • Disengage the the three plastic clips that secure the screen to the circuit board.
  11. Game Boy Screen Replacement: 手順 11、 3の画像 1 Game Boy Screen Replacement: 手順 11、 3の画像 2 Game Boy Screen Replacement: 手順 11、 3の画像 3
    • Flip the circuit board over revealing the device screen.
    • Remove the two screws connecting the screen and the circuit board.
    • Follow the video instructions to desolder the display connectors and replace your screen.
終わりに
45 の人々がこのガイドを完成させました。
作成者
15人の作成者と共同で作成されました。
Andrew Tramposch
メンバー登録日: 06/24/10
2,243 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 3-2, Johann Summer 2010 Cal Poly, Team 3-2, Johann Summer 2010人のメンバー
CPSU-JOHANN-R10S3G2
3 メンバー
34のガイドは作成済み
11 件のコメント
What kind of lcd screen or where can I find one that isn't off of another dmg-01 gameboy?
Floyd Odom - 返信
I was wondering the same. Maybe ebay or Amazon.
Joshua Graham -
What about the new display? Where to get it?
No spare part necessary should be replaced with a link where to buy a new one.
Helmut Kohli - 返信
You can’t buy a new replacement screen unfortunately. Not only is it very difficult to remove the screen, it’s impossible to buy a replacement. They’d be better showing us how to fix a screen. There’s plenty of videos on YT showing how to fix blank vertical line but hardly any on how to fix horizontal lines, and the ones that do don’t work very well.
Firegoose - 返信
Where do I buy a replacement screen for a 1989 game boy?
Nathan Thurston - 返信
コメントを追加
統計データ:
過去 24時間: 36
過去 7 日: 372
過去 30 日: 2,030
今までの合計 134,797
