はじめに
Use this guide to replace the evaporator cover of your freezer.
The evaporator cover helps to channel air from various parts of the refrigerator through the cold evaporator and evaporator fan. It also protects the evaporator and fan from damage. It functions as the rear wall of the freezer compartment and has vents to allow for directed airflow.
The evaporator cover does not usually fail, except if it becomes unfastened, or if it is plastic, it cracks. In such case the airflow will be affected and the cooling ability of the refrigerator will be reduced.
This guide was created using a GE model GSH25KGMB BB side-by-side refrigerator. Other GE side-by-side units should be similar.
必要な工具と部品
Unplug your refrigerator before you begin your repair.
Condenser fan motor
Compressor motor and thermal overload device
Water supply valve assembly
Grasp the ice bin and lift it upward slightly.
Pull the bin out of the freezer compartment and remove it.
Lift the front edge of the cover 1cm (1/2") and pull the cover out of the freezer compartment.
Use a 1/4" nut driver to loosen or remove the two screws securing the ice maker in place.
Lift the icemaker upward to allow the mounting keyholes to slip over the screw heads.
Disconnect ice maker plug by loosening the retainer clips by lifting them if possible and then pulling the plug out of the socket. The socket is shown with the plug removed.
Remove the ice maker from the freezer compartment.
Use a 1/4" nut driver to remove the two screws securing the ice auger motor to its support brackets.
Lift the ice auger motor to the right to free it from the left hand support bracket.
Lower the ice auger motor to the left, forward and down to allow it to clear the right hand support bracket.
Lower the auger motor assembly so that you can access the electrical connection.
Squeeze the locking tabs on the connector to release it from the socket and pull it out to disconnect it.
Remove the ice auger motor assembly.
Lift the right edge of the shelf to free it from the clips which secure it.
Once the shelf is lifted, move it to the right and free the tabs on the left edge.
Remove the shelf.
Repeat this for each of the freezer shelves.
Use a #2 Phillips screwdriver to remove the retaining screws securing the lower evaporator cover.
Use a 1/4" nut driver to remove the four screws securing the evaporator fan cover to the rear of the refrigerator.
