はじめに
Use this guide to replace the ice maker in your GE side-by-side refrigerator.
The ice maker produces ice automatically. The ice produced is stored in the ice storage bin.
If the ice maker fails, no ice may be produced, the ice maker inlet may freeze and cause leaks, or the ice may not be properly harvested. In these cases, the ice maker will likely need replacement.
This guide was created using a GE model GSH25KGMB BB side-by-side refrigerator. Other GE side-by-side units should be similar.
必要な工具と部品
Unplug your refrigerator before you begin your repair.
Condenser fan motor
Compressor motor and thermal overload device
Water supply valve assembly
Grasp the ice bin and lift it upward slightly.
Pull the bin out of the freezer compartment and remove it.
Lift the front edge of the cover 1cm (1/2") and pull the cover out of the freezer compartment.
Use a 1/4" nut driver to loosen or remove the two screws securing the ice maker in place.
Lift the icemaker upward to allow the mounting keyholes to slip over the screw heads.
Disconnect ice maker plug by loosening the retainer clips by lifting them if possible and then pulling the plug out of the socket. The socket is shown with the plug removed.
Remove the ice maker from the freezer compartment.
