メインコンテンツにスキップ
GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement
必要な工具と部品
  1. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Battery Compartment Cover: 手順 1、 3の画像 1 GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Battery Compartment Cover: 手順 1、 3の画像 2 GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Battery Compartment Cover: 手順 1、 3の画像 3
    • Find the battery compartment on the bottom of the clock radio.
    • Using your thumb, push the compartment cover latch toward the battery.
    • With the latch pushed in, pull the compartment cover upward to remove it..
  2. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Battery: 手順 2、 2の画像 1 GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Battery: 手順 2、 2の画像 2
    • Lift the battery from the compartment.
    • Pull the battery up and gently disconnect it from the battery connector.
  3. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Screws: 手順 3、 2の画像 1 GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Screws: 手順 3、 2の画像 2
    • Using a Phillips #00 Screwdriver, unscrew the six 12mm screws from around the bottom of the clock radio.
  4. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, LCD Cover: 手順 4、 1の画像 1
    • Gently pull the liquid crystal display (LCD) cover off.
  5. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Clock Radio: 手順 5、 2の画像 1 GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Clock Radio: 手順 5、 2の画像 2
    • Lift the top off. Two gray, plastic internal pieces will fall out when you do this; set them aside.
  6. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Speaker: 手順 6、 2の画像 1 GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Speaker: 手順 6、 2の画像 2
    • Grip the speaker.
    • Lift the speaker from the holder.
    • Turn the speaker over.
  7. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Speaker from Wires: 手順 7、 3の画像 1 GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Speaker from Wires: 手順 7、 3の画像 2 GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Speaker from Wires: 手順 7、 3の画像 3
    • The red wire is the + and the tan wire is the -. These wires are connected with solder.
    • Apply the hot soldering iron tip to the speaker connection solder.
    • Pull the speaker away from the wires.
  8. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, New Speaker: 手順 8、 3の画像 1 GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, New Speaker: 手順 8、 3の画像 2 GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, New Speaker: 手順 8、 3の画像 3
    • Attach a new 65 mm speaker, model #115048352530, with the wire connectors. Match the red wire to the + and the tan wire to the -.
    • Solder the wires to connect. Let the solder cool.
    • Reverse Step 6 to insert the new speaker in holder.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Dominick Giguere
メンバー登録日: 10/28/14
848 ポイント
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 27
今までの合計 1,618
