メインコンテンツにスキップ
GE 29875GE1 Motherboard Replacement
必要な工具と部品
  1. GE 29875GE1 Motherboard Replacement, Removing Foam Feet: 手順 1、 2の画像 1 GE 29875GE1 Motherboard Replacement, Removing Foam Feet: 手順 1、 2の画像 2
    この手順で使用する道具:
    購入する
    • Begin by looking at the bottom face of the device. Use tweezers to remove the four foam pads which are covering the four screws.
  2. GE 29875GE1 Motherboard Replacement, Removing the Back Casing: 手順 2、 1の画像 1
    • Use a Phillips head #2 screwdriver to remove the four screws from the bottom of the device. These screw heads are sized 5.3mm (or .209").
  3. GE 29875GE1 Motherboard Replacement, Separating the Device: 手順 3、 1の画像 1
    • Remove the back casing panel by gently pulling back on it until you are able to reach inside. Gently pull the microphone out of its housing. This allows you to pull the device apart.
    • The red circle indicated on the picture marks where the microphone housing is found.
  4. GE 29875GE1 Motherboard Replacement, Disconnecting the Speaker: 手順 4、 1の画像 1
    • Use a soldering iron to heat up the two solder connections where the speaker wire is attached to the motherboard. This will separate the speaker from the board.
    • If you are having trouble with this step, refer to the guide found here.
  5. GE 29875GE1 Motherboard Replacement, Unscrewing the Motherboard: 手順 5、 1の画像 1
    • Remove the two screws holding the motherboard to the casing. Use a Phillps head #2 screwdriver.
    • These screw heads are also sized 5.3mm (or .209in).
  6. GE 29875GE1 Motherboard Replacement, Disconnecting the Microphone: 手順 6、 2の画像 1 GE 29875GE1 Motherboard Replacement, Disconnecting the Microphone: 手順 6、 2の画像 2
    • Use the soldering iron to heat up the two solder connections where the microphone wires are attached to on the motherboard. This will separate the microphone from the board.
    • Once the two screws holding the motherboard in place are removed, the motherboard can be taken out of the device and replaced.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Evan
メンバー登録日: 10/29/14
196 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team 4-6, Miles Fall 2014 UMass Dartmouth, Team 4-6, Miles Fall 2014人のメンバー
UMASSD-MILES-F14S4G6
3 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 9
今までの合計 376
