メインコンテンツにスキップ
Fusion5 5.5 Gen II Front & Rear Camera Replacement
必要な工具と部品
  1. Fusion5 5.5 Gen II Front & Rear Camera Replacement, Back Cover: 手順 1、 2の画像 1 Fusion5 5.5 Gen II Front & Rear Camera Replacement, Back Cover: 手順 1、 2の画像 2
    • Hold the device with the screen facing away from you and the back of the device facing you.
    • Locate the groove at the bottom corner of the device.
    • Begin prying the back cover of the device off from the groove and working your way around the outside edges of the device.
  2. Fusion5 5.5 Gen II Front & Rear Camera Replacement, Midframe: 手順 2、 2の画像 1 Fusion5 5.5 Gen II Front & Rear Camera Replacement, Midframe: 手順 2、 2の画像 2
    • Remove thirteen 3mm Phillips #00 screws from the midframe.
    • Remove the single 5mm Phillips #0 screw below the camera.
  3. Fusion5 5.5 Gen II Front & Rear Camera Replacement: 手順 3、 2の画像 1 Fusion5 5.5 Gen II Front & Rear Camera Replacement: 手順 3、 2の画像 2
    • Using an opening pick, begin prying one of the top corners to remove the midframe from the device.
    • Be careful not to damage the cables inside the device when you pry the midframe off.
  4. Fusion5 5.5 Gen II Front & Rear Camera Replacement, Front & Rear Camera: 手順 4、 1の画像 1
    この手順で使用する道具:
    購入する
    • Using tweezers, flip the brown tab securing the ribbon cable.
    • Make sure to only lift the flap and not the connector socket due to its susceptibility to break off.
  5. Fusion5 5.5 Gen II Front & Rear Camera Replacement: 手順 5、 1の画像 1
    • Using the tweezers, grab the ribbon cable and pull it out from its connector.
    • Then pull the front camera component out of its socket on the motherboard.
  6. Fusion5 5.5 Gen II Front & Rear Camera Replacement: 手順 6、 1の画像 1
    • Using tweezers, grasp the ribbon cable's metal tab and gently lift it to disconnect it from its connector on the motherboard.
    • Make sure to only lift by the metal tab and not the connector socket due to its susceptibility to break off.
  7. Fusion5 5.5 Gen II Front & Rear Camera Replacement: 手順 7、 2の画像 1 Fusion5 5.5 Gen II Front & Rear Camera Replacement: 手順 7、 2の画像 2
    • You may now grab and lift the rear-facing camera out of its socket on the motherboard.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Hwajin
メンバー登録日: 09/16/19
560 ポイント
5のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 318
