この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Replacing the hard drive for the Fujitsu Lifebook U810 can be a simple process if directions are followed carefully. The only tool required is a Phillips head +J0 sized screwdriver to remove the Phillips screws on the back of the LifeBook. This guide improves the memory and speed of the device. You can find a new hard drive online by searching the model number and corresponding part for the U810 model.
必要な工具と部品
Remove back cover of the device by unscrewing the four 7mm screws with a Phillips #0 screwdriver.
コメント 1 件
Is there a BIOS whitelist for this machine? I wanted to replace my wifi card due to OS incompatibility but I've seen conflicting reports.
