メインコンテンツにスキップ
Fujifilm FinePix S8630 Speaker Replacement
必要な工具と部品
  1. Fujifilm FinePix S8630 Speaker Replacement, Battery Door: 手順 1、 1の画像 1
    • Remove the M3 x 4mm screws from the bottom of your device as indicated by the picture. using the Philips Head J0 Screw Driver Bit .
  2. Fujifilm FinePix S8630 Speaker Replacement: 手順 2、 1の画像 1
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the left side of the device as indicated by the pictures.
  3. Fujifilm FinePix S8630 Speaker Replacement: 手順 3、 1の画像 1
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the right side of the device as indicated by the pictures.
  4. Fujifilm FinePix S8630 Speaker Replacement: 手順 4、 2の画像 1 Fujifilm FinePix S8630 Speaker Replacement: 手順 4、 2の画像 2
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the camera flash lid as indicated by the picture.
    • Remove the plastic cover from the flash lid by gentle pulling them apart or using the plastic opening tool.
  5. Fujifilm FinePix S8630 Speaker Replacement: 手順 5、 1の画像 1
    • Fold the lid down in order to access and remove the final M3 x 4mm screw using your Philips Head Screwdriver.
  6. Fujifilm FinePix S8630 Speaker Replacement: 手順 6、 3の画像 1 Fujifilm FinePix S8630 Speaker Replacement: 手順 6、 3の画像 2 Fujifilm FinePix S8630 Speaker Replacement: 手順 6、 3の画像 3
    • Use the plastic opening tool to pry the back and front casings of the camera apart.
    • Once pried apart use your hands to pull off the back plate of the camera.
    • You will need to apply a little bit of force to remove the back plate.
  7. Fujifilm FinePix S8630 Speaker Replacement: 手順 7、 3の画像 1 Fujifilm FinePix S8630 Speaker Replacement: 手順 7、 3の画像 2 Fujifilm FinePix S8630 Speaker Replacement: 手順 7、 3の画像 3
    • Once the back plate is removed twist the battery cover clockwise and it should easily dislodge.
  8. Fujifilm FinePix S8630 Speaker Replacement, LCD Screen: 手順 8、 3の画像 1 Fujifilm FinePix S8630 Speaker Replacement, LCD Screen: 手順 8、 3の画像 2 Fujifilm FinePix S8630 Speaker Replacement, LCD Screen: 手順 8、 3の画像 3
    • Gently pull the tab out of the motherboard and then the LCD screen should easily be removed.
  9. Fujifilm FinePix S8630 Speaker Replacement, Speaker: 手順 9、 3の画像 1 Fujifilm FinePix S8630 Speaker Replacement, Speaker: 手順 9、 3の画像 2 Fujifilm FinePix S8630 Speaker Replacement, Speaker: 手順 9、 3の画像 3
    • Using your Philips head screwdriver remove the screws from the metal shield.
    • Remove the metal shield.
  10. Fujifilm FinePix S8630 Speaker Replacement: 手順 10、 3の画像 1 Fujifilm FinePix S8630 Speaker Replacement: 手順 10、 3の画像 2 Fujifilm FinePix S8630 Speaker Replacement: 手順 10、 3の画像 3
    • Find the speaker and gently pull away from the motherboard. It is just on by an adhesive.
    • Identify where the speaker is connected to the motherboard and unsolder both of the connections,
    • Guide for Soldering: はんだ付けとはんだ除去の作業ガイド
終わりに
作成者
4人の作成者と共同で作成されました。
Colton Lancsarics
メンバー登録日: 02/10/16
731 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team 3-2, Sullivan Spring 2016 USF Tampa, Team 3-2, Sullivan Spring 2016人のメンバー
USFT-SULLIVAN-S16S3G2
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 9
今までの合計 338
