メインコンテンツにスキップ
Front License Plate Installation
必要な工具と部品
  1. Front License Plate Installation, Front License Plate Installation: 手順 1、 3の画像 1 Front License Plate Installation, Front License Plate Installation: 手順 1、 3の画像 2 Front License Plate Installation, Front License Plate Installation: 手順 1、 3の画像 3
    • Gather your tools. Drill, Sharpie, Drill Bits, Painters Tape.
    • Get the parts, too. The front license plate bracket and the 4 plastic spreader rivets.
    • Don't forget the Touareg :)
    • Use Painters Tape to mark your drill bits at 1/2" of depth - so you don't drill into the bumper too far.
  2. Front License Plate Installation: 手順 2、 2の画像 1 Front License Plate Installation: 手順 2、 2の画像 2
    • Position the license plate frame and center it on the VW emblem and parking camera (below, if installed). You can use the vertical supports in the lower grill (hard to see in this pic) to assist in alignment.
    • Hold the license plate frame in place using some painters tape.
    • Using the Sharpie, mark the four holes that you'll be drilling.
  3. Front License Plate Installation: 手順 3、 1の画像 1
    • Remove the frame for easier drilling.
    • Using the 1/8" drill bit, drill four pilot holes in the center of each position.
    • Finish the holes by enlarging them with the 11/32" drill bit.
  4. Front License Plate Installation: 手順 4、 2の画像 1 Front License Plate Installation: 手順 4、 2の画像 2
    • Place the frame back into position.
    • Install the four plastic spreader rivets.
    • Ensure they are seated by using a socket (as shown) to ensure rivets are fully seated before pushing in the center pin.
  5. Front License Plate Installation: 手順 5、 3の画像 1 Front License Plate Installation: 手順 5、 3の画像 2 Front License Plate Installation: 手順 5、 3の画像 3
    • Tap the center pins of the rivets so they are flush with the rivet body.
    • Use #10 x 1/2" Stainless Steel Screws to affix the plate to the mounting bracket. You can see slight indentations where the screws are to go. I drilled pilot holes first.
    • Don't use the "standard" license plate hardware that is 3/4" long. Those screws appear to be long enough to hit the bumper when inserted.
ゴール
8 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Justin
メンバー登録日: 10/27/12
1,565 ポイント
3のガイドは作成済み
6件のガイドコメント
I would like to know where the license plate bracket/frame was purchased.
ruthkoljonen - 返信
Nice instructions! I bought my Touareg from Honda dealer with no front plate holder. They ordered me the holder but it came with no instructions. These were perfect! Thank you!!!
TRENT MATTHEWS - 返信
Really, VW. $45,000+ for an ID.4 and *I* have to drill holes in the body to mount the license. This stinks.
E F Charles LaBerge - 返信
Utter bullshit that this is my task
XXX - 返信
This was immensely helpful and the install went seamlessly. THANK YOU JUSTIN!
I had to go buy an 11/32 bit but that was definitely a perfect size for those plastic rivets.
FYI - if anyone is wondering you need to get the part from your VW Dealer, not from some aftermarket/Amazon outfit. Mine was made in Slovakia same as the car and it fit perfectly.
...and yes, my car was from Alberta, Canada and they only use one plate because they are the renegade province of Canada!!
604Pete - 返信
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 11
過去 30 日: 88
今までの合計 28,308
