メインコンテンツにスキップ
Framework Laptop 16" Display Replacement
必要な工具と部品
  1. Framework Laptop 16" Display Replacement, Before you begin: 手順 1、 2の画像 1 Framework Laptop 16" Display Replacement, Before you begin: 手順 1、 2の画像 2
    • Unplug all cables and fully shut down your laptop.
    • If your repair requires a spudger, a T5 Torx, or a Phillips screwdriver, you can use the included Framework screwdriver. Whichever works best for you!
  2. Framework Laptop 16" Display Replacement, Create a gap: 手順 2、 3の画像 1 Framework Laptop 16" Display Replacement, Create a gap: 手順 2、 3の画像 2 Framework Laptop 16" Display Replacement, Create a gap: 手順 2、 3の画像 3
    • The bezel is secured with magnets!
    • Slide your fingernail under the inside edge of either bottom corner of the bezel.
    • Pull the bezel away from the screen to release the first few magnets.
  3. Framework Laptop 16" Display Replacement, Remove the bezel: 手順 3、 3の画像 1 Framework Laptop 16" Display Replacement, Remove the bezel: 手順 3、 3の画像 2 Framework Laptop 16" Display Replacement, Remove the bezel: 手順 3、 3の画像 3
    • Lift the bezel around the perimeter of the screen until all of its magnets are released.
    • Remove the bezel.
  4. Framework Laptop 16" Display Replacement, Remove the display screws: 手順 4、 3の画像 1 Framework Laptop 16" Display Replacement, Remove the display screws: 手順 4、 3の画像 2 Framework Laptop 16" Display Replacement, Remove the display screws: 手順 4、 3の画像 3
    • Use a T5 Torx screwdriver to remove the four 2.4 mm‑long screws securing the display.
    • During reassembly, support the screen frame with your other hand as you reinsert screws to prevent the laptop from accidentally tipping over.
  5. Framework Laptop 16" Display Replacement, Disconnect the display: 手順 5、 3の画像 1 Framework Laptop 16" Display Replacement, Disconnect the display: 手順 5、 3の画像 2 Framework Laptop 16" Display Replacement, Disconnect the display: 手順 5、 3の画像 3
    • Grab the display and pull it straight off the screen frame to free it from its alignment pegs.
    • Don't pull the display too far from the frame, as it's still attached by a cable.
    • Flip the front of the display down and rest it on the keyboard.
  6. Framework Laptop 16" Display Replacement: 手順 6、 2の画像 1 Framework Laptop 16" Display Replacement: 手順 6、 2の画像 2
    • Use your fingers to flip up the plastic tab and access the connector underneath.
  7. Framework Laptop 16" Display Replacement: 手順 7、 2の画像 1 Framework Laptop 16" Display Replacement: 手順 7、 2の画像 2
    • Use the flat end of a spudger to lift up the metal locking tab over the display connector.
  8. Framework Laptop 16" Display Replacement, Remove the display: 手順 8、 3の画像 1 Framework Laptop 16" Display Replacement, Remove the display: 手順 8、 3の画像 2 Framework Laptop 16" Display Replacement, Remove the display: 手順 8、 3の画像 3
    • Grip the display cable where it meets the connector head.
    • Slide the connector straight out of its socket to disconnect it.
    • Remove the display.
終わりに
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
2 の人々がこのガイドを完成させました。
Alex Diaz-Kokaisl
メンバー登録日: 01/16/22
213,566 ポイント
1,040のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
23,649のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 51
今までの合計 1,205
