メインコンテンツにスキップ
Flipper Zero iButton board Replacement
必要な工具と部品
    • Go to Main Menu > Settings > Power.
    • Select Power OFF.
    • Alternatively, you can press and hold the Back-button for around 10 seconds.
    • Confirm by pressing the Right-button.
  1. Flipper Zero iButton board Replacement, Remove the microSD card: 手順 2、 1の画像 1
    • Eject the microSD card by pressing it with your fingernail.
  2. Flipper Zero iButton board Replacement, Remove the screws: 手順 3、 1の画像 1
    この手順で使用する道具:
    Phillips #0 Screwdriver
    $5.49
    • Use a PH0 screwdriver to unscrew the four long screws holding the back cover.
    • Be careful, the screws are quite easy to strip.
  3. Flipper Zero iButton board Replacement, Open the back cover: 手順 4、 3の画像 1 Flipper Zero iButton board Replacement, Open the back cover: 手順 4、 3の画像 2 Flipper Zero iButton board Replacement, Open the back cover: 手順 4、 3の画像 3
    • Press the middle of the top cover on both sides, one by one, to release the latches that hold the back cover in place.
    • Once the latches are released, you can remove the bottom cover.
  4. Flipper Zero iButton board Replacement, Seperate the chassis from the top cover: 手順 5、 2の画像 1 Flipper Zero iButton board Replacement, Seperate the chassis from the top cover: 手順 5、 2の画像 2
    この手順で使用する道具:
    $5.49
    • Use a PH0 screwdriver to unscrew the two short screws that are holding the chassis and top cover together.
    • Once the screws are removed, separate the chassis from the top cover.
  5. Flipper Zero iButton board Replacement, Disconnect the battery: 手順 6、 1の画像 1
    この手順で使用する道具:
    Spudger
    $3.99
    • Disconnect the battery by carefully prying the connector with a Spudger and pulling it out.
  6. Flipper Zero iButton board Replacement, Disconnect the ribbon cable: 手順 7、 2の画像 1 Flipper Zero iButton board Replacement, Disconnect the ribbon cable: 手順 7、 2の画像 2
    この手順で使用する道具:
    iFixit Opening Picks (Set of 6)
    • Disconnect the small ribbon cable from the board. Use a plastic pick to lift the latch up to open the lock and carefully pull it out of the connector.
  7. Flipper Zero iButton board Replacement, Remove the iButton board: 手順 8、 2の画像 1 Flipper Zero iButton board Replacement, Remove the iButton board: 手順 8、 2の画像 2
    この手順で使用する道具:
    $5.49
    • Unscrew the short screw holding the iButton board in place using a PH0 screwdriver.
    • Once the screw is removed, carefully remove the iButton board.
  8. Flipper Zero iButton board Replacement, Remove the cable from the iButton board: 手順 9、 2の画像 1 Flipper Zero iButton board Replacement, Remove the cable from the iButton board: 手順 9、 2の画像 2
    この手順で使用する道具:
    Spudger
    $3.99
    • To disconnect the flat cable from the iButton board, use a Spudger to carefully release the lock by pulling the latch up.
    • Once the connector is unlocked, gently pull the cable out of the connector.
終わりに
作成者
1人の作成者と共同作成されました。
Sebastian
メンバー登録日: 08/19/18
31,055 ポイント
71のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 14
過去 30 日: 44
今までの合計 1,884
