メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Fix Oculus Quest 2 Controller Drift
必要な工具と部品
    1. Fix Oculus Quest 2 Controller Drift, Remove Battery From Controller: 手順 1、 1の画像 1
      • Open the battery compartment and remove the AA battery inside.
      FixBotに聞いてみる
      コメントを追加
    2. Fix Oculus Quest 2 Controller Drift, Remove Controller Faceplate: 手順 2、 2の画像 1 Fix Oculus Quest 2 Controller Drift, Remove Controller Faceplate: 手順 2、 2の画像 2
      • Remove the black plastic faceplate using an iFixit opening tool, Jimmy, or even a flathead screwdriver.
      • The plate is secured with adhesive and might be difficult to remove for the first time. You don't need to worry as the plate is additionally held in place with plastic posts.
      FixBotに聞いてみる
      コメントを追加
    3. Fix Oculus Quest 2 Controller Drift, Remove Joystick Cap: 手順 3、 1の画像 1
      • Gently pull on the top of the joystick until the cap comes off of the joystick.
      • The cap might not detach from the touch sensor spring. In that case, let the spring remain attached to the joystick cap and don’t forcibly remove it. If you do this, it's very difficult to reattach without damage to the spring.
      • There is a spring that's located between the joystick housing and the cap. Don't bend or break this spring as it controls the touch sensor.
      FixBotに聞いてみる
      コメントを追加
    4. Fix Oculus Quest 2 Controller Drift, Clean Controller Joystick: 手順 4、 1の画像 1
      • Start by spraying some compressed air into the joystick housing to get rid of any large particles inside.
      • Apply a small amount of contact cleaner or 90% or greater isopropyl alcohol to the joystick and move the joystick around, and then wait for it to dry.
      • Only use electrical contact cleaner or 90% or greater isopropyl alcohol. Other soaps and substances might be conductive and damage your controller.
      • Make sure to wait for the contact cleaner or isopropyl alcohol to dry before reassembling.
      FixBotに聞いてみる
      コメントを追加
終わりに
To reassemble your device, follow these instructions in reverse order. If you need a video demonstrating these steps, one can be found here.
キャンセル: このガイドを終了できませんでした。
100 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Seizure Salad
メンバー登録日: 01/12/18
2,773 ポイント
2のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
334 メンバー
3,569のガイドは作成済み
49件のガイドコメント
I did that and it works, but now the touch sensor on the thumb stick doesn’t work. Any ideas?
briangerrard - 返信 共有
The spring that goes between the joystick housing and the cap is what connects the touch sensor to the controller. While i did not inspect the cap to see for myself i believe there should be a metal contact on the underside of the cap that the spring should be touching.
Tl;dr: Make sure the spring between the joystick cap and housing is properly connected to both sides.
Erik Sørhage - 返信 共有
Thanks, just what i needed.
Just one problem.
You never mention the spring that goes between the joystick housing and the cap. I understand that you took it off completely to get a better picture, but to me it seems better to not take it off completely and just let the joystick cap hang by the spring while you spray cleaner down into the housing. As long as you're careful not to bend or break the spring i believe this would lower the chance of the touch sensor not working like one of the users here already have problems with.
Otherwise the guide is good and on-point.
I should mention tho, i bought my quest on day one so perhaps my controller is an earlier model. On my controller the spring between the joystick cap and housing wasn't easily removable from either side, which is why i decided to leave the cap hanging. It could be that on later models the spring is not connected to the cap but instead is just pressing up against it.
The spring is still there! It might be a bit hard to see however and I’ll note that in the guide.
Seizure Salad - 返信 共有
コメントを追加
統計データ:
過去 24時間: 21
過去 7 日: 165
過去 30 日: 850
今までの合計 230,326
