メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
First Act MA2039 Damaged Wire Replacement
必要な工具と部品
    1. First Act MA2039 Damaged Wire Replacement, First Act MA2039 Damaged Wire Replacement: 手順 1、 2の画像 1 First Act MA2039 Damaged Wire Replacement, First Act MA2039 Damaged Wire Replacement: 手順 1、 2の画像 2
      • Place the speaker with its front side facing down.
      • Use a Phillips #0 screwdriver to remove the two 25 mm screws from the left and right sides of the battery cartridges.
      • Open both lids to the battery cartridges.
      FixBotに聞いてみる
      コメントを追加
    2. First Act MA2039 Damaged Wire Replacement: 手順 2、 3の画像 1 First Act MA2039 Damaged Wire Replacement: 手順 2、 3の画像 2 First Act MA2039 Damaged Wire Replacement: 手順 2、 3の画像 3
      • As you begin to lift the back panel off the amplifier, push the battery terminals through the open slots of the battery cartridges.
      • Use your fingers to prop the back panel and lift it away from the amplifier.
      • Lift the back panel off completely and set it to the side.
      FixBotに聞いてみる
      コメントを追加
    3. First Act MA2039 Damaged Wire Replacement: 手順 3、 3の画像 1 First Act MA2039 Damaged Wire Replacement: 手順 3、 3の画像 2 First Act MA2039 Damaged Wire Replacement: 手順 3、 3の画像 3
      • With the back panel off, this will help make space for the silver compartment to be removed.
      • Unscrew four 25 mm screws with a Phillips #0 screwdriver from the top of the amplifier.
      • Press firmly on the input jack and tone adjustment knob of the silver compartment to free it from its resting position.
      FixBotに聞いてみる
      コメントを追加
    4. First Act MA2039 Damaged Wire Replacement: 手順 4、 3の画像 1 First Act MA2039 Damaged Wire Replacement: 手順 4、 3の画像 2 First Act MA2039 Damaged Wire Replacement: 手順 4、 3の画像 3
      • Rotate the silver compartment so that you have a clear visual of the motherboard and its components.
      • For effective work on the wiring, lodge the compartment on top of the back portion of the amplifier.
      • Check the wiring components for blown fuses or damaged connections.
      FixBotに聞いてみる
      コメントを追加
    5. First Act MA2039 Damaged Wire Replacement: 手順 5、 1の画像 1
      • Lift the silver compartment to see where the wires are further connected.
      • Make sure that the terminals from the circuit to the amplifier are connected securely.
      • Check to see if there is loose wiring from the motherboard.
      • If there is damaged wire to the amplifier or motherboard in the silver compartment, refer this Soldering guide to replace wires and fix connections.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
3人の作成者と共同で作成されました。
Luke VanBuskirk
メンバー登録日: 04/05/18
279 ポイント
2のガイドは作成済み
チーム
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 8
過去 30 日: 21
今までの合計 702
