メインコンテンツにスキップ
Fast Fix Extension cord Repair
必要な工具と部品
  1. Fast Fix Extension cord Repair, Extension cord Repair: 手順 1、 1の画像 1
    • Repairing an extension cord is a relatively simple process that anyone can do at home. This is the cord that we will repair.
    • Disconnect the cable before carrying out any repair work.
    • Use a utility knife to cleanly cut the cable and expose the interior wires.
  2. Fast Fix Extension cord Repair: 手順 2、 2の画像 1 Fast Fix Extension cord Repair: 手順 2、 2の画像 2
    • Use wire strippers to remove about 5cm of the outer insulation from the cable.
    • Remove around a centimeter of insulation from the inner wires to reveal the bare copper using the wire strippers.
    • Do the same for the other side of the extension cord.
  3. Fast Fix Extension cord Repair: 手順 3、 1の画像 1
    • Take the two halves of the extension and join the corresponding wires together. Neutral wire N (blue wire); The phase L wire (red, black or brown); The ground wire (green and yellow).
    • Twist the copper wires together.
  4. Fast Fix Extension cord Repair: 手順 4、 3の画像 1 Fast Fix Extension cord Repair: 手順 4、 3の画像 2 Fast Fix Extension cord Repair: 手順 4、 3の画像 3
    • Solder the joints of the wires with a soldering gun.
    • For help with soldering, check out our How to Solder and Desolder Connections guide.
    • It may help to use a vice grip or similar to hold one end of the wires in place, so that you can manipulate the other side with your hands.
    • If necessary, you can rectify any blisters or spikes in the soldering using a small hammer.
    • Once you've soldered all of the connections, check with the ohmmeter that the current flows well from one end of the extension cord to the other. If it does not, check to make sure that the solder has made a firm connection with each side of each cable pair. It may help to reflow the soldered connections.
  5. Fast Fix Extension cord Repair: 手順 5、 1の画像 1
    • Use electrical tape to insulate each of the inner wires.
  6. Fast Fix Extension cord Repair: 手順 6、 1の画像 1
    • After covering all connections individually with electrical tape. Then cover the entire wire harness with retractable sheath thermosetting tube.
    • Apply heat from a hairdryer or heat gun to the heat shrink tubing until it is wrapped tightly around the cable.
  7. Fast Fix Extension cord Repair: 手順 7、 1の画像 1
    • This is how your extension cord will look like after you finished to repair it.
ゴール
3 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Belgony Nsimba
メンバー登録日: 05/05/20
208 ポイント
1ガイドが承認済み
チーム
UW Tacoma, Team S16-G16, Cardinal Spring 2020 UW Tacoma, Team S16-G16, Cardinal Spring 2020人のメンバー
UWT-CARDINAL-S20S16G16
1 メンバー
3のガイドは作成済み
1件のガイドコメント
Be sure to slide the section of thermosetting tube onto one of the cord ends before soldering the wires. The tube should be cut to a length that will cover the repair section and overlap the adjacent outer insulation by 1.5cm on each side of the repair. After soldering, slide the tube over the repair and heat shrink it.
lw3685 - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 29
過去 30 日: 168
今までの合計 18,389
