メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Fairphone 3 Bottom Module Replacement
必要な工具と部品
  1. Fairphone 3 Bottom Module Replacement, Back Cover: 手順 1、 2の画像 1 Fairphone 3 Bottom Module Replacement, Back Cover: 手順 1、 2の画像 2
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom right of the back cover.
    • Pry the back cover up to start separating its plastic clips.
    FixBotに聞いてみる
  2. Fairphone 3 Bottom Module Replacement: 手順 2、 3の画像 1 Fairphone 3 Bottom Module Replacement: 手順 2、 3の画像 2 Fairphone 3 Bottom Module Replacement: 手順 2、 3の画像 3
    • Slide around the bottom right corner of the back cover to loosen the lower plastic clips.
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • To reinstall the back cover press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
    FixBotに聞いてみる
  3. Fairphone 3 Bottom Module Replacement, Battery: 手順 3、 2の画像 1 Fairphone 3 Bottom Module Replacement, Battery: 手順 3、 2の画像 2
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
    • Lever the battery up until you can get a good grip.
    FixBotに聞いてみる
  4. Fairphone 3 Bottom Module Replacement: 手順 4、 2の画像 1 Fairphone 3 Bottom Module Replacement: 手順 4、 2の画像 2
    • Lift the battery out of its recess and remove it.
    FixBotに聞いてみる
  5. Fairphone 3 Bottom Module Replacement, Display Assembly: 手順 5、 1の画像 1
    • Whenever a Phillips #00 screw is mentioned you can also unfasten it with a size #0 bit/screwdriver.
    • Remove the thirteen Phillips #00 screws (4 mm length).
    FixBotに聞いてみる
  6. Fairphone 3 Bottom Module Replacement: 手順 6、 3の画像 1 Fairphone 3 Bottom Module Replacement: 手順 6、 3の画像 2 Fairphone 3 Bottom Module Replacement: 手順 6、 3の画像 3
    • Make sure to insert the opening pick between the midframe and the display module and not into the small gap next to the screen. Otherwise you're going to pry up the screen instead of the whole display module.
    • Insert an opening pick between the midframe and the display module on the right edge of the phone.
    • Slide the opening pick down to the bottom right corner to pry open the plastic clamps of the display module.
    FixBotに聞いてみる
  7. Fairphone 3 Bottom Module Replacement: 手順 7、 2の画像 1 Fairphone 3 Bottom Module Replacement: 手順 7、 2の画像 2
    • Slide the opening pick around the bottom right corner and use it to disengage the plastic clamps at the bottom of the display module.
    FixBotに聞いてみる
  8. Fairphone 3 Bottom Module Replacement: 手順 8、 2の画像 1 Fairphone 3 Bottom Module Replacement: 手順 8、 2の画像 2
    • Slide the opening pick along the left side to pry the display module up.
    • The display module should pop out of the midframe during this process. In case it doesn’t, check for remaining clamps you might have missed.
    FixBotに聞いてみる
  9. Fairphone 3 Bottom Module Replacement: 手順 9、 2の画像 1 Fairphone 3 Bottom Module Replacement: 手順 9、 2の画像 2
    • Remove the display assembly.
    • To reinstall the display-module press it into place on all sides until you can hear a snap from the plastic clamps to make sure it sits flush with the frame.
    • If you install a new display: The new display module comes with a white plastic cover held by 2 screws over the processor and the connectors. This needs to be taken off.
    FixBotに聞いてみる
  10. Fairphone 3 Bottom Module Replacement, Bottom Module: 手順 10、 1の画像 1
    • Remove the four 4.1mm-longPhillips #00 screws.
    FixBotに聞いてみる
  11. Fairphone 3 Bottom Module Replacement: 手順 11、 2の画像 1 Fairphone 3 Bottom Module Replacement: 手順 11、 2の画像 2
    • Use a spudger to pry up and disconnect the bottom module connecting cable.
    FixBotに聞いてみる
  12. Fairphone 3 Bottom Module Replacement: 手順 12、 2の画像 1 Fairphone 3 Bottom Module Replacement: 手順 12、 2の画像 2
    • Use your fingers to remove the bottom module.
    FixBotに聞いてみる
終わりに
Information on what to do with the old module can be found on the FairPhone support page and in the FairPhone forum.
44 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Adriana Zwink
メンバー登録日: 12/18/19
66,846 ポイント
167のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
25,721のガイドは作成済み
14件のガイドコメント
Spitze, jetzt lädt mein Fairphone 3 wieder tadellos. Tolle Anleitung!!!
Petra Breit - 返信 共有
Super, das freut uns!
Adriana Zwink - 返信 共有
Thanks for the guide, it was very helpful. However, I'm pretty sure we don't need to remove so many screws on Step 5.
I for one had a hard time removing one, and I left it in place, and I could achieve the repair without any problem.
I think only the 6 screws on the very outside edge, that correspond with the screen's locations for the screws.
mll - 返信 共有
Hello @mll, thank you for sharing your experience with us! We're glad that the repair worked out. I've rechecked the display and the phone assembly. All screws should be removed to make sure not to damage components of the phone. Feel free to check Fairphone's video on replacing the display unit: https://www.youtube.com/watch?v=hG6OVPTn...
@adrianazwink , you are right indeed, and I stand corrected.
mll - 返信 共有
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 51
過去 30 日: 254
今までの合計 22,481
