はじめに
The Eton FRX3 uses a single internal, rechargeable nickel-metal hydride battery. Unfortunately, this battery may not last forever and will slowly lose it's abbility to hold charge over time. But luckily, swapping it out for a brand new one doesn't even require a screwdriver!
Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
To reassemble your device, follow these instructions in the reverse order.
3 の人々がこのガイドを完成させました。
4 件のコメント
Hey mate, you can buy the battery packs from a number of sources. Here's the link to one of those sources https://www.amazon.com/HQRP-FR200-BAT-3A...
james -
is it ok to replace it with a higher capacity lithium battery?
troydeleon - 返信
As long as the specifications match, that should be fine. Just be careful when swapping out components in circuits, as it can potentially destroy the device if they're incompatible!
