メインコンテンツにスキップ
Ematic eGlide 4 Motherboard Replacement
必要な工具と部品
  1. Ematic eGlide 4 Motherboard Replacement, Rear Panel: 手順 1、 1の画像 1
    • Remove the 4.6mm Phillips #00 screw at the base of the device.
  2. Ematic eGlide 4 Motherboard Replacement: 手順 2、 1の画像 1
    • Slide the rear panel away from the base parallel to the screen.
  3. Ematic eGlide 4 Motherboard Replacement: 手順 3、 2の画像 1 Ematic eGlide 4 Motherboard Replacement: 手順 3、 2の画像 2
    • Carefully remove the speakers from the rear panel.
    • Pull the speakers off of the rear panel.
  4. Ematic eGlide 4 Motherboard Replacement, Speaker: 手順 4、 1の画像 1
  5. Ematic eGlide 4 Motherboard Replacement, Motherboard: 手順 5、 1の画像 1
    • Slide the grey ribbon wire connector clip away from the ribbon wire port on the motherboard using the pointed tip of a spudger.
    • You do not need to fully disconnect the ribbon wire clip from the ribbon wire port: the clip will stay attached in a loose fit.
    • Remove the gold ribbon wire from the ribbon wire port on the motherboard.
  6. Ematic eGlide 4 Motherboard Replacement: 手順 6、 1の画像 1
    • Slide the grey ribbon wire connector clip away from the white ribbon wire port on the screen board using the pointed tip of a spudger.
    • Remove the ribbon wire from the ribbon wire port on the screen board.
  7. Ematic eGlide 4 Motherboard Replacement: 手順 7、 1の画像 1
    • Slide the grey ribbon wire connector clip away from the ribbon wire port using the pointed tip of a spudger.
    • Remove the ribbon wire from the ribbon wire port.
    • If you have already removed the side button array you do not need to do this step.
  8. Ematic eGlide 4 Motherboard Replacement: 手順 8、 1の画像 1
    • Remove the 2 Phillips #00 4.5 mm screws from the motherboard.
  9. Ematic eGlide 4 Motherboard Replacement: 手順 9、 1の画像 1
    • Desolder the Wi-Fi Adaptor
    • If not replacing the motherboard or Wi-Fi Adaptor, omit this step
    • See ifixit's guide to soldering and desoldering for help: How to Solder and Desolder Connections
  10. Ematic eGlide 4 Motherboard Replacement: 手順 10、 1の画像 1
    • Desolder the battery connections
    • If not replacing the motherboard or battery, omit this step
  11. Ematic eGlide 4 Motherboard Replacement: 手順 11、 2の画像 1 Ematic eGlide 4 Motherboard Replacement: 手順 11、 2の画像 2
    • Slide and pull the motherboard out of its current position, so that the ports disconnect from the device.
    • Lift the motherboard out of the device.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Bailey Hughes
メンバー登録日: 03/22/15
617 ポイント
6のガイドは作成済み
チーム
Baylor, Team 5-8, Williams Spring 2015 Baylor, Team 5-8, Williams Spring 2015人のメンバー
BU-WILLIAMS-S15S5G8
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 13
今までの合計 301
