メインコンテンツにスキップ
Ematic FunTab 2 Motherboard Replacement
必要な工具と部品
  1. Ematic FunTab 2 Motherboard Replacement, Motherboard: 手順 1、 1の画像 1
    • Remove back of Ematic FunTab by using the plastic opening tool to pry the back open.
  2. Ematic FunTab 2 Motherboard Replacement: 手順 2、 3の画像 1 Ematic FunTab 2 Motherboard Replacement: 手順 2、 3の画像 2 Ematic FunTab 2 Motherboard Replacement: 手順 2、 3の画像 3
    • Next, you need to remove all connections to the motherboard and the device.
    • Start by first removing the tape from all the connections.
    • Be careful not to remove the camera.
  3. Ematic FunTab 2 Motherboard Replacement: 手順 3、 3の画像 1 Ematic FunTab 2 Motherboard Replacement: 手順 3、 3の画像 2 Ematic FunTab 2 Motherboard Replacement: 手順 3、 3の画像 3
    • Remove LCD connector from the LCD.
    • Be sure to flip up the retaining tabs before pulling the LCD connector out. (It is the black tab on the connection port).
  4. Ematic FunTab 2 Motherboard Replacement: 手順 4、 1の画像 1
    この手順で使用する道具:
    • Remove camera connection from camera with tweezers.
    • Again, be sure to flip up the retaining tab before pulling the connector.
  5. Ematic FunTab 2 Motherboard Replacement: 手順 5、 1の画像 1
    • Remove speaker connection from speaker with tweezers.
    • Before pulling the speaker connection make sure the retaining tab is flipped up.
  6. Ematic FunTab 2 Motherboard Replacement: 手順 6、 3の画像 1 Ematic FunTab 2 Motherboard Replacement: 手順 6、 3の画像 2 Ematic FunTab 2 Motherboard Replacement: 手順 6、 3の画像 3
    • Remove wires:
    • Start by removing the black wire on each side.
    • Next, remove the WiFi antenna wire from the motherboard.
    • Finally, remove the yellow, red, and black wires.
    • To put the wires back in their correct locations you will need a soldering iron to solder the wire back in place. You will do this once the motherboard is replaced. Here is a guide on how to solder はんだ付けとはんだ除去の作業ガイド
  7. Ematic FunTab 2 Motherboard Replacement: 手順 7、 3の画像 1 Ematic FunTab 2 Motherboard Replacement: 手順 7、 3の画像 2 Ematic FunTab 2 Motherboard Replacement: 手順 7、 3の画像 3
    • Unscrew all four screws on motherboard with the Phillip's head screwdriver.
    • All of the screws are the same size, and should all fit in either corresponding screw location.
  8. Ematic FunTab 2 Motherboard Replacement: 手順 8、 2の画像 1 Ematic FunTab 2 Motherboard Replacement: 手順 8、 2の画像 2
    • It is now safe to remove and replace the old motherboard with your new motherboard.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Amanda Wolosz
メンバー登録日: 04/05/15
287 ポイント
1ガイドが承認済み
チーム
University of Alabama, Team 1-1, Naidoo Spring 2015 University of Alabama, Team 1-1, Naidoo Spring 2015人のメンバー
UA-NAIDOO-S15S1G1
4 メンバー
4のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 4
今までの合計 1,253
