はじめに
The Electrolux RM-275 Refrigerator works by a process called absorption, rather than the compression process that powers a standard household fridge. Instead of a compressor, it has a small heater, about 100 watts. The heating power source is user-selectable: mains, vehicle battery or gas bottle. The absorption process is less efficient than compression, but is popular for RVs, and camping trailers because of the power source flexibility, and for hotel minibars because it is quiet. This fridge is in a 20-year-old RV. This type of fridge is now made by Dometic, who supply spares for some many old Electrolux-branded fridges - but unfortunately not for this one.
The fridge worked fine on mains power or vehicle power, but it didn't work on gas. To set it to gas, switch on the spark igniter, which sparks about twice a second, with an audible 'tick' and a flash of the switch lamp. Then turn the gas knob to 'full' and press the knob to override the flame failure thermocouple. After a few seconds the gas will flow from the jet and the spark will ignite the flame. The igniter module senses the low resistance through the flame, and automatically stops the sparking and lamp flashing. After half a minute the flame failure thermocouple will be hot, and you can stop pressing the knob.
The problem with this fridge was when the igniter was switched on there was no flashing light, and no tick sound. Removing the covers round the gas jet (as described below) and lighting the gas with a match was successful, and confirmed that the gas supply was OK.
If you wish to remove the spark electrode, remove the metal cover around the gas flame unit. To do this, slacken the screw holding the cover to the fridge rear panel. Also slacken the screw holding the two parts of the cover together. By careful manoevering you can remove the metal cover parts separately.
Fit the replacement spark electrode, with tip pointing downwards, at the correct location as remembered from the previous step. The electrode tip should be 5mm (3/16 in) from the metal gas jet. Adjust the thermocouple to its previous position and tighten the screw to secure the clamp.The thermocouple tip should be in the gas flame.
New line.
Check if the old igniter cover will fit the replacement igniter module. It may be necessary to make a new cover. For the new igniter I used a small plastic box from a local electronics store (Maplin). Make a hole to pass the spark electrode wire, and a small cutout to allow the other 3 wires.
ある他の人がこのガイドを完成しました。
