メインコンテンツにスキップ
Edwin the Duck Speaker Replacement
必要な工具と部品
  1. Edwin the Duck Speaker Replacement, Speaker: 手順 1、 2の画像 1 Edwin the Duck Speaker Replacement, Speaker: 手順 1、 2の画像 2
    • Unscrew the four 9mm screws with a T8 bit
    • Remove the back plate off
  2. Edwin the Duck Speaker Replacement: 手順 2、 2の画像 1 Edwin the Duck Speaker Replacement: 手順 2、 2の画像 2
    • Carefully take off the rubber skin.
    • Be patient and don't rush. You don't want to rip or damage the rubber skin resulting in not having a waterproof cover.
  3. Edwin the Duck Speaker Replacement: 手順 3、 1の画像 1
    • Using the J1 bit, unscrew all six 9 mm screws that run along the border.
  4. Edwin the Duck Speaker Replacement: 手順 4、 2の画像 1 Edwin the Duck Speaker Replacement: 手順 4、 2の画像 2
    • Use the plastic opening tool to open the inside of the duck.
    • Be very careful when splitting the two halves apart. There are wires connecting to both sides. So open it very slowly.
  5. Edwin the Duck Speaker Replacement: 手順 5、 2の画像 1 Edwin the Duck Speaker Replacement: 手順 5、 2の画像 2
    • Using the plastic opening tool, pull up the black tab up until it stops.
    • Be careful not to pull the black tab too far up, otherwise the cable won't be able to secure anymore.
    • Pull up the white cable tab up slowly
  6. Edwin the Duck Speaker Replacement: 手順 6、 2の画像 1 Edwin the Duck Speaker Replacement: 手順 6、 2の画像 2
    • Use the J1 bit to unscrew all four screws attached to the motherboard.
    • Use the J1 bit to unscrew both 9 mm screw attached to the white plastic plate.
  7. Edwin the Duck Speaker Replacement: 手順 7、 1の画像 1
    • Lift up the motherboard and speaker, and place to the side like done so in the image.
  8. Edwin the Duck Speaker Replacement: 手順 8、 2の画像 1 Edwin the Duck Speaker Replacement: 手順 8、 2の画像 2
    • Take the speaker and by using the soldering iron, unsolder by the red and white wires.
    • For more detailed information on how to solder and desolder connections, please see this guide.
    • Replace the new speaker and solder the two wires back into place. The red wire goes on the left and white wire goes on the right.
終わりに
作成者
4人の作成者と共同で作成されました。
Tanner Mowbray
メンバー登録日: 10/18/17
101 ポイント
1ガイドが承認済み
チーム
UW Tacoma, Team S1-G4, Rose Fall 2017 UW Tacoma, Team S1-G4, Rose Fall 2017人のメンバー
UWT-ROSE-F17S1G4
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 15
今までの合計 284
