メインコンテンツにスキップ
Eclipse 180G2 MP3 Video Player speaker Replacement
必要な工具と部品
  1. Eclipse 180G2 MP3 Video Player speaker Replacement, Outer Case: 手順 1、 2の画像 1 Eclipse 180G2 MP3 Video Player speaker Replacement, Outer Case: 手順 1、 2の画像 2
    • Remove the two screws on the bottom of the device with a Phillips head screwdriver.
    • Use a spudger to remove the plastic plate from the bottom of the player.
  2. Eclipse 180G2 MP3 Video Player speaker Replacement, Remove inner circuit from case shell: 手順 2、 3の画像 1 Eclipse 180G2 MP3 Video Player speaker Replacement, Remove inner circuit from case shell: 手順 2、 3の画像 2 Eclipse 180G2 MP3 Video Player speaker Replacement, Remove inner circuit from case shell: 手順 2、 3の画像 3
    • Hold the device firmly between two fingers. Be sure you aren't holding down the top of the device; the circuit board will slide out of the shell through that end.
    • Use the spudger to push the USB port on the bottom of the device inward.
    • The plastic LCD cover and the key pad will now be free; they were held in place by the tension between the case and the internal circuit board.
  3. Eclipse 180G2 MP3 Video Player speaker Replacement, Internal Speaker: 手順 3、 2の画像 1 Eclipse 180G2 MP3 Video Player speaker Replacement, Internal Speaker: 手順 3、 2の画像 2
    • Identify the speaker. Pull the speaker away from the device so that wires are exposed.
    • Using a wire cutter, sever the red and black cables that are connecting the speaker to the circuit board.
    • You will need to solder the new speaker wires to connect it to the device.
終わりに
  • To reassemble your device after completion of replacement, follow these instructions in reverse order.
2 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Jesse Minor
メンバー登録日: 01/15/15
668 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 1-4, Tanski Winter 2015 USF Tampa, Team 1-4, Tanski Winter 2015人のメンバー
USFT-TANSKI-W15S1G4
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 10
今までの合計 935
