はじめに
This guide will walk you through how to replace the battery of the device. In order to do this you must first remove the back cover. Once the back cover is off, you can remove and replace the battery.
必要な工具と部品
この手順で使用する道具:Plastic Cards$2.99
Insert the plastic card under the battery and use it to remove the battery from the device.
終わりに
