はじめに
If most of the coffee runs into the bowl, the seals in the drain valve may be hardened or the white cap on the valve plunger may be cracked. Here we show you how to replace them.
必要な工具と部品
The brewing group has already been removed and disassembled. Now it's time for the drainage valve.
There will be many pictures
All you need a small flathead screwdriver.
When assembling, make sure that the lips of the seals point to the pressure side, i.e. inward, and the flat side outward.
When installing, make sure that the pressure hose runs through the slot in the valve carrier.
Apply a thin layer of food-safe silicone grease to the seals before installation.
Follow the steps in reverse order to reassemble your device.
3 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
