メインコンテンツにスキップ
Disassembling the Thomas Ride On Train
必要な工具と部品
  1. Disassembling the Thomas Ride On Train, Preparation: 手順 1、 1の画像 1
    • You will need quite a lot of space to work on the engine as it effectively has to be stripped right down to get to the key components
    • Before commencing, remove the battery from the system. This will make the train lighter and avoid any electrical issues. See Replacing the battery guide.
  2. Disassembling the Thomas Ride On Train, Removing the wheel cover: 手順 2、 2の画像 1 Disassembling the Thomas Ride On Train, Removing the wheel cover: 手順 2、 2の画像 2
    • Turn the train upside down
    • Remove the screws down the centre and across the front to release the wheel cover
    • You may need to lever the cover out at the front with something like a putty knife
    • Remove the loudspeaker by unscrewing the 3 screws that attach it to this cover.
  3. Disassembling the Thomas Ride On Train, Removing the front wheels: 手順 3、 1の画像 1
    • The front two pairs of wheels are screwed on with self tapping screws. Remove the four screws that hold on each of the wheels and keep safe
    • Reassembly
    • When screwing the wheels back on note that there are counterbores in the plastic clips that fit onto the raised parts on the case
  4. Disassembling the Thomas Ride On Train, Removing the engine: 手順 4、 1の画像 1
    • The electric motor is held in place by two different things.
    • Firstly two screws and a yellow plastic bracket.
    • Also on the right is a clip that hold the motor and gearbox in place. You can release this by inserting a pallet knife or a screwdriver between the motor and case
    • Note that you won't be able to completely remove the engine at this point as it is still connected by wires
  5. Disassembling the Thomas Ride On Train, Removing the side panels: 手順 5、 1の画像 1
    • Over the wheel arches are 2 more plastic panels, they are held in place by screws. Note that the outer screws are a smaller size.
  6. Disassembling the Thomas Ride On Train, Removing the body: 手順 6、 2の画像 1 Disassembling the Thomas Ride On Train, Removing the body: 手順 6、 2の画像 2
    • The next 5 screws hold the body to the chassis. The top also is clipped in place at the back
    • You can access most of the components at this point including disconnecting the motor and the power switch
    • Reassembly
    • Take care not to trap wires, you should be able to route the cables around the case
  7. Disassembling the Thomas Ride On Train, Power Switch: 手順 7、 1の画像 1
    • The power is connected via spade connectors.
    • Make a note of their position before removing.
    • By removing the three screws you can access the switch which is an off the shelf double pole double throw switch but only one throw is used.
    • This had broken in my train but I simply reversed it to use the other throw which did work correctly. This might be an option if you can't find a replacement part.
  8. Disassembling the Thomas Ride On Train, Removing the chimney: 手順 8、 1の画像 1
    • To access the controls you need to remove the chimney, this step may require a shorter or stubby screwdriver
    • Once the screws are removed the chimney slides up with respect to the body
    • Reassembly
    • Take care to ensure that all of the wires pass through the large hole and are not trapped
  9. Disassembling the Thomas Ride On Train, Removing the handlebars: 手順 9、 1の画像 1
    • A single screw inside the chimney holds this in place, again you may need a short screwdriver to access this
  10. Disassembling the Thomas Ride On Train, Removing the console: 手順 10、 3の画像 1 Disassembling the Thomas Ride On Train, Removing the console: 手順 10、 3の画像 2 Disassembling the Thomas Ride On Train, Removing the console: 手順 10、 3の画像 3
    • The console is held in place by the 4 inner screws, note you don't need to remove the outer screws or screws in the handlebars
    • Note how the block attached to the lever is positioned against the switch. In my train this was 180degrees reversed and hence the lever did not do anything.
    • The three buttons need to be correctly orientated, they have little bars to fit into slots
    • Note the newer model may look slightly different to this
終わりに
作成者
1人の作成者と共同作成されました。
Andy from Workshopshed
メンバー登録日: 05/21/13
420 ポイント
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 45
今までの合計 4,739
