はじめに
This speaker contains 3 main PCB's. One is for audio control, one is for power control, and the other (and largest) is for audio amplification. To access any of them for replacement, you must first open up the metal electronics box.
必要な工具と部品
Remove the 8 Phillips screws from the back of the speaker.
There are two silver, 6 mm-long machine screws with two 1/8" inner-diameter washers on the exterior of the metal electronics box; remove these first using a #2 philips screwdriver.
There are five of the same type of machine screw (silver, 6 mm-long) remaining around the metal electronics box's exterior; remove these as well.
Remove the 4, 7/32" long machine screws with a #2 phillips head screwdriver.
5 の人々がこのガイドを完成させました。
2 件のコメント
[|hello sir i am using behringer b215 d eurolive active speaker and power controler ic shot in one spesker and his ic code is this]-VIPer22A (4C6107) and please solve my this problems can you help me
If problem exist please contact stprofessionals@gmail.com
They're from Lahore they'll solve your problem. Email them get their contact and go to the store and have your all equipment fixed.
