この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Removing the cover of the Apple IIc is the precursor to any repair on a computer and it allows you to view the eternal workings of this device.
必要な工具と部品
10 の人々がこのガイドを完成させました。
3 件のコメント
The //c is designed to be popped open. Remove the 6 screws as described. Flip the handle down and tip the //c 3-4 inches over a hard surface and let it drop. The handle will pop the rear catches off safely.
It looks and sounds scary but it's how Apple trained dealer techs to open the machine. There isn't anything in a //c that is shock sensitive.
Sean Fahey - 返信
Just wanted you to know that your method is superior. I repair a lot of Apple IIC. Spudger method always results in broken plastic tabs. Your method never results in any damage.
