はじめに
Speaker volume is low or audio is distorted are symptoms of a faulty speaker. Please review our troubleshooting page Digiland 10.1'' DL1016 Troubleshooting before proceeding to the replacement. Once you have determined your symptoms and are certain you need a speaker replacement, continue on with this guide.
This guide will help you replace the speaker of a Digiland 10.1” DL1016 device
必要な工具と部品
手順1 Digiland 10.1'' DL1016 Remove Backing
注意: 手順 1-2 は、作業進行中としてマークされている ガイド から引用されています。
Use an opening pick and an opening tool to pry the backing off the back of the tablet.
Pull back the black flaps on the ZIF cable connectors.
Pull the ribbon cables out of the connectors.
手順4 Digiland 10.1'' DL1016 Remove Battery
注意: 手順 4 は、作業進行中としてマークされている ガイド から引用されています。
There is glue that holds the battery down, so carefully pry it open. You may need to use some force.
The speakers are marked in red.
Disconnect the speaker connections.
Remove the speakers.
