はじめに
This guide shows how to remove and replace the control module for the Dewalt Nailers DCN680D1 2018.
The module is an all-in-one assembly, which includes the trigger mechanism, battery connector, and selector switch board.
必要な工具と部品
Remove the following screws securing the outer housing:
Twelve T10 screws
One 2.5 mm hex screw
Carefully flip the device over.
Remove the left housing from the device.
Use a T20 driver to remove the two screws (one on either side) securing the back support .
Use a T10 driver to remove the three screws securing the motor wires
Lift and remove the control module from the device.
Reassembly tip: Make sure that the white plastic actuator latches into the black lever arm.
Remove the white plastic actuator from the control module and transfer it onto your replacement part.
When you install the actuator, make sure the actuator bar can press the white button on the control module.
ある他の人がこのガイドを完成しました。
