メインコンテンツにスキップ
Dell chromebook 3180 Trackpad Replacement
必要な工具と部品
  1. Dell chromebook 3180 Trackpad Replacement, Remove Battery Screws: 手順 1、 1の画像 1
    • Remove the 3 battery screws with a phillips #00 screwdriver.
    • Remove the battery from the motherboard extension connector
    • Disconnect the trackpad data cable from the trackpad and the motherboard.
    • Then at the bottom of the trackpad, move the speaker wire from the rubber clips.
    • Remove the 6 screws from the retaining bracket
    • Remove the retaining bracket by lifting it away from the trackpad
    • Keep the tape you see that is connected to the retaining bracket and the back of the trackpad.
    • Remove the trackpad which sits under the retaining bracket.
    • Insert the new trackpad upside down onto the palmrest so it sits flush against the trackpad screw ports.
    • Insert the new retaining bracket with the black rubber speaker clips facing up. These clips will help secure the speaker wire that runs across the palmrest as seen in the next step.
    • Replace the 6 retaining bracket screws
    • Replace and secure the speaker wire that runs along the back of the retaining bracket.
    • Replace Battery on top of completed trackpad
終わりに
作成者
3人の作成者と共同で作成されました。
Jon
メンバー登録日: 08/18/13
3,921 ポイント
22のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 7
今までの合計 303
