メインコンテンツにスキップ
Dell XPS 15 9510 Display Assembly Replacement
必要な工具と部品
  1. Dell XPS 15 9510 Display Assembly Replacement, Lower Case: 手順 1、 1の画像 1
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
  2. Dell XPS 15 9510 Display Assembly Replacement: 手順 2、 1の画像 1
    • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
    • Wedge the case apart with a nylon spudger.
    • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
    • Slide spudger along each side of the laptop
  3. Dell XPS 15 9510 Display Assembly Replacement: 手順 3、 1の画像 1
    • Lift the back panel of the laptop off and set it aside.
  4. Dell XPS 15 9510 Display Assembly Replacement, Display Assembly: 手順 4、 1の画像 1
    • Remove the four screws (eight total) from each display hinge using a Phillips #00 screwdriver.
  5. Dell XPS 15 9510 Display Assembly Replacement: 手順 5、 1の画像 1
    • Remove five screws that connect the display using a Phillips #00 screwdriver.
  6. Dell XPS 15 9510 Display Assembly Replacement: 手順 6、 1の画像 1
    • Carefully remove the display from the Dell XPS 15 9510.
終わりに
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
作成者
6人の作成者と共同で作成されました。
Austin Sa
メンバー登録日: 03/30/22
432 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team 1-3, Mellen Spring 2022 UMass Dartmouth, Team 1-3, Mellen Spring 2022人のメンバー
UMASSD-MELLEN-S22S1G3
3 メンバー
5のガイドは作成済み
2 件のコメント
Missing a very important step.
Two small screws above the display cable clamp - Step 5 - need to be removed. If you look at the picture in step 5, the far left red/orange circle actually contains one. You can spot it inside and at the top of the of the circle. You can't separate the display assembly without removing those 2 screws.
Joshua Kleier - 返信
Aren't there any cables that need to be removed?
Ned Eff - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 20
過去 30 日: 63
今までの合計 3,628
