メインコンテンツにスキップ
Dell XPS 14 RAM Replacement
必要な工具と部品
  1. Dell XPS 14 RAM Replacement, Back Panel: 手順 1、 1の画像 1
    • Position the computer back side up so that the “XPS” logo is facing you.
    • Remove six 3 mm screws along the perimeter of the back panel using a T5 Torx screwdriver.
  2. Dell XPS 14 RAM Replacement: 手順 2、 3の画像 1 Dell XPS 14 RAM Replacement: 手順 2、 3の画像 2 Dell XPS 14 RAM Replacement: 手順 2、 3の画像 3
    • Use an opening tool to pry up the metal plate.
    • Remove the two 6 mm screws under the silver flap using a Phillips #0 screwdriver.
  3. Dell XPS 14 RAM Replacement: 手順 3、 2の画像 1 Dell XPS 14 RAM Replacement: 手順 3、 2の画像 2
    • Use an opening tool to pop out the back panel.
    • Once unhinged, the panel will open away from you.
    • The back panel will still be attached by a ribbon cable. Be cautious when opening the panel to ensure the ribbon stays intact.
  4. Dell XPS 14 RAM Replacement: 手順 4、 3の画像 1 Dell XPS 14 RAM Replacement: 手順 4、 3の画像 2 Dell XPS 14 RAM Replacement: 手順 4、 3の画像 3
    • Flip over the back panel so that the interior of the panel is facing up.
    • Remove three 2 mm screws that are connected to the vendor GCE disk on the bottom left corner of the back panel using a Phillips #0 screwdriver.
    • Remove the black plastic cover that holds the disk in place.
    • Remove the back panel.
    • The GCE disk should still be connected to the computer via a purple ribbon cable.
  5. Dell XPS 14 RAM Replacement, Speaker: 手順 5、 2の画像 1 Dell XPS 14 RAM Replacement, Speaker: 手順 5、 2の画像 2
    • Remove four 2 mm screws that are connected to the speaker using a Phillips #0 screwdriver.
  6. Dell XPS 14 RAM Replacement: 手順 6、 2の画像 1 Dell XPS 14 RAM Replacement: 手順 6、 2の画像 2
    • Remove the speaker from its original location so the wire connector is visible.
    • Unplug the red and white cable plug by pulling out the white end tag.
    • The speaker is now fully removed.
  7. Dell XPS 14 RAM Replacement, Battery: 手順 7、 1の画像 1
    • Make sure to ground yourself before removing the battery.
    • Remove the four 6 mm screws from the sides of the battery using a T5 Torx screwdriver.
    • Remove the two 3 mm screws from the top of the battery using a Phillips #0 screwdriver.
  8. Dell XPS 14 RAM Replacement: 手順 8、 3の画像 1 Dell XPS 14 RAM Replacement: 手順 8、 3の画像 2 Dell XPS 14 RAM Replacement: 手順 8、 3の画像 3
    • Detach the battery connector from the motherboard using two thumbs to pop it out.
    • Remove the battery from the laptop.
  9. Dell XPS 14 RAM Replacement, RAM: 手順 9、 3の画像 1 Dell XPS 14 RAM Replacement, RAM: 手順 9、 3の画像 2 Dell XPS 14 RAM Replacement, RAM: 手順 9、 3の画像 3
    • Remove any electrical tape that may be covering or overlapping the RAM cartridge.
    • Push the two metal latches on either side of the RAM outward.
    • The cartridge will pop out of the laptop.
  10. Dell XPS 14 RAM Replacement: 手順 10、 2の画像 1 Dell XPS 14 RAM Replacement: 手順 10、 2の画像 2
    • Slide the RAM cartridge out of its slot.
終わりに
作成者
2人の作成者と共同で作成されました。
Gabriella Monico
メンバー登録日: 03/23/22
457 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team 1-3, Botvin Spring 2022 UMass Dartmouth, Team 1-3, Botvin Spring 2022人のメンバー
UMASSD-BOTVIN-S22S1G3
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 25
今までの合計 261
