メインコンテンツにスキップ
Dell XPS 13 9300 SSD Replacement
必要な工具と部品
  1. Dell XPS 13 9300 SSD Replacement, Unfasten the lower case: 手順 1、 2の画像 1 Dell XPS 13 9300 SSD Replacement, Unfasten the lower case: 手順 1、 2の画像 2
    • Use a T5 Torx screwdriver to remove the eight 3.3 mm screws securing the case.
  2. Dell XPS 13 9300 SSD Replacement, Insert an opening pick: 手順 2、 2の画像 1 Dell XPS 13 9300 SSD Replacement, Insert an opening pick: 手順 2、 2の画像 2
    • Insert an opening pick between the lower case and the chassis on the front right edge.
  3. Dell XPS 13 9300 SSD Replacement, Release the case's front clips: 手順 3、 2の画像 1 Dell XPS 13 9300 SSD Replacement, Release the case's front clips: 手順 3、 2の画像 2
    • Slide the pick along the front edge to release the clips securing the lower case.
  4. Dell XPS 13 9300 SSD Replacement, Release the remaining clips: 手順 4、 3の画像 1 Dell XPS 13 9300 SSD Replacement, Release the remaining clips: 手順 4、 3の画像 2 Dell XPS 13 9300 SSD Replacement, Release the remaining clips: 手順 4、 3の画像 3
    • Continue sliding the opening pick along the perimeter of the lower case to release the remaining clips.
  5. Dell XPS 13 9300 SSD Replacement: 手順 5、 3の画像 1 Dell XPS 13 9300 SSD Replacement: 手順 5、 3の画像 2 Dell XPS 13 9300 SSD Replacement: 手順 5、 3の画像 3
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  6. Dell XPS 13 9300 SSD Replacement, Disconnect the battery: 手順 6、 3の画像 1 Dell XPS 13 9300 SSD Replacement, Disconnect the battery: 手順 6、 3の画像 2 Dell XPS 13 9300 SSD Replacement, Disconnect the battery: 手順 6、 3の画像 3
    • Grip the pull tab on the battery connector with your fingers and gently pull away from the socket to disconnect it.
    • After you disconnect the battery, some of your laptop's startup (BIOS) settings will revert to their defaults.
    • You may need to run BIOS setup to reset the system clock as well as any specialized disk settings before you can boot up your XPS.
  7. Dell XPS 13 9300 SSD Replacement, Loosen the antenna wire: 手順 7、 3の画像 1 Dell XPS 13 9300 SSD Replacement, Loosen the antenna wire: 手順 7、 3の画像 2 Dell XPS 13 9300 SSD Replacement, Loosen the antenna wire: 手順 7、 3の画像 3
    • Use the flat end of a spudger to pry up and loosen the antenna wire from the SSD cover.
    • Repeat this process along the entire edge of the SSD cover.
  8. Dell XPS 13 9300 SSD Replacement, Unfasten the SSD cover: 手順 8、 2の画像 1 Dell XPS 13 9300 SSD Replacement, Unfasten the SSD cover: 手順 8、 2の画像 2
    • Use a Phillips screwdriver to remove the 3.6 mm screw securing the SSD cover
  9. Dell XPS 13 9300 SSD Replacement, Remove the SSD cover: 手順 9、 3の画像 1 Dell XPS 13 9300 SSD Replacement, Remove the SSD cover: 手順 9、 3の画像 2 Dell XPS 13 9300 SSD Replacement, Remove the SSD cover: 手順 9、 3の画像 3
    • Pull the SSD cover away from its fastener to remove it.
  10. Dell XPS 13 9300 SSD Replacement, Remove the SSD: 手順 10、 3の画像 1 Dell XPS 13 9300 SSD Replacement, Remove the SSD: 手順 10、 3の画像 2 Dell XPS 13 9300 SSD Replacement, Remove the SSD: 手順 10、 3の画像 3
    • Pull the SSD out of its socket and remove it. Keep the SSD as parallel to the motherboard as possible when pulling on it.
    • Do not pull up at a sharp angle, as this could damage the SSD and the socket.
  11. Dell XPS 13 9300 SSD Replacement, Reassembly notes: 手順 11、 1の画像 1
終わりに
Take your e-waste to an R2 or e-stewards certified recycler.
Repair didn't go as planned? Try some basic troubleshooting, or ask our Dell XPS answers community for help.
作成者
3人の作成者と共同で作成されました。
Spencer Day
メンバー登録日: 09/14/22
155,036 ポイント
1,033のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
23,765のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 56
今までの合計 2,397
