はじめに
This guide will show you how to safely remove the frame from the body of the Dell Venue 11 Pro to access the internal components. It is also a prerequisite to all other replacement guides on this page except for the battery.
必要な工具と部品
Turn your device over to the backside. On the notch at the bottom portion of the tablet, use your fingers to lift up the back cover.
To disconnect the left ribbon cable from the motherboard, place the flat end of your spudger under the edge of the pop connector and pry the connector straight up.
The right ribbon cable has a ZIF connector. Use the flat end of your spudger to lift up the small locking flap, then pull out the cable.
2 の人々がこのガイドを完成させました。
