メインコンテンツにスキップ
Dell Streak 7 Screen Replacement
必要な工具と部品
  1. Dell Streak 7 Screen  Replacement, Front Panel Assembly: 手順 1、 1の画像 1
    • Insert the spudger under the capacitive button panel, and slide the spudger all the way around.
    • You will want to heat up the screen edges with the iOpener to help facilitate removal.
  2. Dell Streak 7 Screen  Replacement: 手順 2、 1の画像 1
    • Remove the button cover by lifting the cover away from the tablet.
  3. Dell Streak 7 Screen  Replacement: 手順 3、 1の画像 1
    • Using the Torx screwdriver, remove the 4mm screws.
  4. Dell Streak 7 Screen  Replacement: 手順 4、 1の画像 1
    • With the Torx screwdriver, remove the two 5mm screws.
  5. Dell Streak 7 Screen  Replacement: 手順 5、 2の画像 1 Dell Streak 7 Screen  Replacement: 手順 5、 2の画像 2
    • Using the spudger, insert it under the black side panel. Slide the spudger all the way around until the cover piece comes off.
    • With the Torx screwdriver, remove the two 4mm screws.
  6. Dell Streak 7 Screen  Replacement: 手順 6、 1の画像 1
    • Use the spudger to go along the edges of the device and pop out the latches securing the display to the case.
  7. Dell Streak 7 Screen  Replacement: 手順 7、 2の画像 1 Dell Streak 7 Screen  Replacement: 手順 7、 2の画像 2
    • Ribbon cables are very sensitive and prone to breaking
    • Disconnect the ribbon cables by unlocking the connector and pulling the cable out slowly.
    • Make sure all the cables are unplugged before opening the device completely. Failure to do so might lead to broken or torn cables.
  8. Dell Streak 7 Screen  Replacement, Screen: 手順 8、 1の画像 1
    • Using the screwdriver, remove the 3mm Torx T5 screws around the metal housing.
  9. Dell Streak 7 Screen  Replacement: 手順 9、 1の画像 1
    この手順で使用する道具:
    購入する
    • Using tweezers, peel off the tape securing the screen to the metal cage around it.
  10. Dell Streak 7 Screen  Replacement: 手順 10、 2の画像 1 Dell Streak 7 Screen  Replacement: 手順 10、 2の画像 2
    • Pull out the ribbon cables through the opening in the metal cage.
    • Lift up the metal cage surrounding the screen by swinging the cage from one side.
  11. Dell Streak 7 Screen  Replacement: 手順 11、 1の画像 1
    • Remove the screen by lifting the screen from the front glass.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Ali Benjelloun
メンバー登録日: 10/02/16
376 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 4-6, Passmore Fall 2016 USF Tampa, Team 4-6, Passmore Fall 2016人のメンバー
USFT-PASSMORE-F16S4G6
3 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 480
