メインコンテンツにスキップ
Dell Streak 7 Motherboard Replacement
必要な工具と部品
  1. Dell Streak 7 Motherboard Replacement, Front Panel Assembly: 手順 1、 1の画像 1
    • Insert the spudger under the capacitive button panel, and slide the spudger all the way around.
    • You will want to heat up the screen edges with the iOpener to help facilitate removal.
  2. Dell Streak 7 Motherboard Replacement: 手順 2、 1の画像 1
    • Remove the button cover by lifting the cover away from the tablet.
  3. Dell Streak 7 Motherboard Replacement: 手順 3、 1の画像 1
    • Using the Torx screwdriver, remove the 4mm screws.
  4. Dell Streak 7 Motherboard Replacement: 手順 4、 1の画像 1
    • With the Torx screwdriver, remove the two 5mm screws.
  5. Dell Streak 7 Motherboard Replacement: 手順 5、 2の画像 1 Dell Streak 7 Motherboard Replacement: 手順 5、 2の画像 2
    • Using the spudger, insert it under the black side panel. Slide the spudger all the way around until the cover piece comes off.
    • With the Torx screwdriver, remove the two 4mm screws.
  6. Dell Streak 7 Motherboard Replacement: 手順 6、 1の画像 1
    • Use the spudger to go along the edges of the device and pop out the latches securing the display to the case.
  7. Dell Streak 7 Motherboard Replacement: 手順 7、 2の画像 1 Dell Streak 7 Motherboard Replacement: 手順 7、 2の画像 2
    • Ribbon cables are very sensitive and prone to breaking
    • Disconnect the ribbon cables by unlocking the connector and pulling the cable out slowly.
    • Make sure all the cables are unplugged before opening the device completely. Failure to do so might lead to broken or torn cables.
  8. Dell Streak 7 Motherboard Replacement, Headphone Jack: 手順 8、 1の画像 1
    • Using the spudger, disconnect the ribbon cable by lifting up on the connector.
    • Ribbon cables are fragile and easily broken.
  9. Dell Streak 7 Motherboard Replacement: 手順 9、 2の画像 1 Dell Streak 7 Motherboard Replacement: 手順 9、 2の画像 2
    • Pull the headphone jack up, away from the case.
  10. Dell Streak 7 Motherboard Replacement, GSM Module: 手順 10、 2の画像 1 Dell Streak 7 Motherboard Replacement, GSM Module: 手順 10、 2の画像 2
    • With the spudger, disconnect the antenna cable located on the module.
  11. Dell Streak 7 Motherboard Replacement: 手順 11、 2の画像 1 Dell Streak 7 Motherboard Replacement: 手順 11、 2の画像 2
    この手順で使用する道具:
    購入する
    • Using tweezers, remove the tape connected to the GSM module.
  12. Dell Streak 7 Motherboard Replacement: 手順 12、 2の画像 1 Dell Streak 7 Motherboard Replacement: 手順 12、 2の画像 2
    • Remove the two 3mm screws securing the GSM module. Use the Torx screwdriver.
  13. Dell Streak 7 Motherboard Replacement: 手順 13、 1の画像 1
    • Disconnect the GSM module by lifting the module up, out of the case.
  14. Dell Streak 7 Motherboard Replacement, Motherboard: 手順 14、 3の画像 1 Dell Streak 7 Motherboard Replacement, Motherboard: 手順 14、 3の画像 2 Dell Streak 7 Motherboard Replacement, Motherboard: 手順 14、 3の画像 3
    • Using the spudger, disconnect the front camera by lifting up on the connector.
  15. Dell Streak 7 Motherboard Replacement: 手順 15、 1の画像 1
    • Using the Torx screwdriver, remove the six 3mm screws .
  16. Dell Streak 7 Motherboard Replacement: 手順 16、 2の画像 1 Dell Streak 7 Motherboard Replacement: 手順 16、 2の画像 2
    • Lift up the metal cover.
  17. Dell Streak 7 Motherboard Replacement: 手順 17、 1の画像 1
    • Use the spudger to lift the vibration motor out of the case.
  18. Dell Streak 7 Motherboard Replacement: 手順 18、 1の画像 1
    • Pull out the motherboard and the battery.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Jair Garcia Varela
メンバー登録日: 09/29/16
301 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 4-6, Passmore Fall 2016 USF Tampa, Team 4-6, Passmore Fall 2016人のメンバー
USFT-PASSMORE-F16S4G6
3 メンバー
12のガイドは作成済み
コメント 1 件
do you know any website or if you guys even sell the board to him
leonardo_hitman - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 337
