はじめに
If your laptop cannot connect to the cellular network it may be due to the WWAN card. Follow this guide to help properly replace the WWAN card.
必要な工具と部品
Remove the 8mm screw in the middle from the laptop with the J1 screwdriver.
Then slide the back plate off.
2 件のコメント
Holy !&&* this is misleading. All of this “Kolin Doyle” person’s guides are idiotic and basic, everybody knows how to take a %#*@ battery out of a laptop! And as Jason said, the guide is totally incorrect, that’s the wrong %#*@ slot for gosh sake; that slot is for a WWAN card that allows connecting to a cellular network, the WiFi card is under the plastic cover on the right, above the heatpipes, and you can even see an antenna cable! Please, mods, delete this incorrect guide and the rest of the guides this person has published; the Latitude e6510 is the easiest laptop to service that I personally own and this guy is making it look hard.
